Pro*AM meshing of external flows
Old   February 18, 2005, 05:04
Default Pro*AM meshing of external flows
Cb
Hello
I was wondering how to mesh an external flow using pro*am. I searched the Forum and found that I need to create a shell 'box' around the model I want to mesh.
So, if i have a .stl file, do I import it, create a new surface in pro*am and then make the shells using the star guide? And does it matter how big the shells are on the box faces?
Once the box is created, how do I select that it is the volume between it and the shape that is to be meshed, and not the imported .stl volume?
Thanks for the help everyone.
Old   February 18, 2005, 06:23
Default Re: Pro*AM meshing of external flows
ted
You don't need to generate an external box for external flows. In the "Advanced Options ..." of the Mesh generation panel, there's the option to flip shell orientation. This will generate a mesh on the outside of your surface, not on the inside.
Old   February 18, 2005, 06:31
Cb
ted, thanks a lot for the help.
So if I have something like a wing profile, and I flip the shell orientation, how do I control the shape of and how large the external flow domain becomes?
CFX best practice for external flows siw CFX 5 May 3, 2009 22:44
Inlet turbulent boundary condition, external flows ROOZBEH Main CFD Forum 1 February 6, 2009 12:37
Boundary conditions for external flows ryan_m OpenFOAM Running, Solving & CFD 3 May 19, 2008 09:49
Modelling external flows; chimneys owen myles Main CFD Forum 3 August 18, 2006 19:16
pro-am meshing of external flows Joel Davison Siemens 1 January 16, 2002 05:37
