March 21, 2005, 10:28 |
pmovlink
I am doing transient flow analysis in an ic engine using cfd.when i issue pmovlink command the following message comes
ENTER CASE NAME euro21 GEOMETRY FILE TITLE *** ERROR *** FILE .evn HAS NOT BEEN PREPARED IN PROSTAR, PLEASE USE EVPREP BEFORE GEOM COMMANDS AND RERUN even after issuing evprep command and writing geom file.why is it so please help me Thanku in advance varun |
March 21, 2005, 13:36 |
Re: pmovlink
Is there a .evn file in your directory?
March 21, 2005, 21:23 |
Re: pmovlink
yes there is an .evn file in my directory
March 22, 2005, 09:17 |
Re: pmovlink
What happens in the output window of star when you type 'evfi conn'?
March 22, 2005, 09:24 |
Re: pmovlink
First of all thanku for the prompt help.when i type evfile conn it is connecting showing the number of events etc.
March 23, 2005, 09:18 |
Re: pmovlink
Your case seems to be OK. This is really strange...
When you prepare your case, do you issue this command (evfi conn) before writing the case ('geom .geom' and 'prob .prob')? Do you get any error when writing the geometry file ('geom .geom')? |
March 22, 2005, 17:17 |
Re: pmovlink
Close the .evn-file, or do a "quit,save" to terminate prostar (and automatly close the .evn-file)
Regards,, Roger |
PMOVLINK and STARLINK | Harendra | Siemens | 3 | November 3, 2004 15:02 |
PMOVLINK for windows | Bhaskar | Siemens | 3 | November 1, 2004 21:11 |
pmovlink script | Arnab | Siemens | 4 | August 1, 2004 22:50 |
How to run PMOVLINK script? | Serkan Cetin | Siemens | 1 | May 1, 2003 12:54 |
pmovlink problems | Jerry Huang | Siemens | 0 | June 20, 2002 20:40 |
