Running HPC
Old   April 8, 2005, 05:25
Default Running HPC
Shazlan
I'm using StarCD v3.22 and Windows XP. I have two question regarding running star parallelly.
1. I'm trying to run my analysis on a single computer with two processors. The .geom and .prob have been written correctly - If I run star sequentially, I face no problem. However, only one processor is utilized if I run star this way. But, when I choose the 'Parallel (Single Host)' option, I received error message as below:
d:\Shazlan\Toilet\2nd Try\toinew_0001>set CDLMD_LICENSE_FILE= d:\Shazlan\Toilet\2nd Try\toinew_0001>REM set STAR="/C/CDadapco/STAR-CD/STAR/3.22.000/windows-x86-absoft_8.2a-dso" root process failed to write port to file FAIL - process exited with code 0
I shut down my anitvirus and Windows XP SP2 firewall and yet, the problem still exist. What should I do next?
2. This time, I want to run star on two computers, which are networked together with 1 processor each computer. I chose the 'Parallel (Multiple Host)' option. However, there's an error saying:
pushd \\acer3\pnp_dir_2005-04-07_16-50-26 Z:\> "\\acer3\star322\lib\loader\star.exe"
Z:\> popd process 2 on Vtc-tr-004 exited without calling MPIFinalize Sending kill commands to launched processes process 0 on Acer3 exited without calling MPIFinalize process 1 on Vtc-tr-002 exited without calling MPIFinalize
What may the problem be?
Helps are highly appreciated! Thanks.
Old   April 8, 2005, 13:34
Default Re: Running HPC
try
try to open a STAR-Shell from the starlauncher's help. Launch your parallel job from there according to user-guide chapter 2:
star -dp -mpi-mpich node1,1 node2,2
tip: on windows try to use star shell as much as possible when problems
ps: avoid using spaces in the file names...
Running in patch when your license is running out Andrew CFX 2 August 9, 2007 13:48
Running a *.cas on many PC ? Cyril FLUENT 0 February 15, 2006 10:05
Not running Mahbub Siemens 5 December 19, 2003 09:33
Running CFX on a cluster jvk CFX 9 September 19, 2002 22:22
Anyone running under XP? Karl FLUENT 1 June 4, 2002 22:28
