Ultra high temperature?
Old   July 18, 2005, 03:03
Default Ultra high temperature?
bk
I am using sorsca.f and sorent.f to consider of scalar genetraion due to high temperature( more than 1.0e6K) with the option-multi component specific heat, viscosity etc... But Looking at star.info, I found the follwing message;
| DOMAIN: star_0001 |
TIME STEP = 4; ELAPSED TIME = 0.800000E-10 s; TABLE/USER CODING
*** WARNING #090 *** VALUE ELOG*YPLUS OR ELOG*EFFVIS/(CAPPA*VISCOS) IS LESS THAN 1.1 AT 100 CELLS.
UPLUS=YPLUS LAW IS USED. IF THIS SITUATION PERSISTS, INCORRECT RESULTS MAY BE OBTAINED.
MAXIMUM COURANT NUMBER = 1.154E-03 AT CELL 7900 MEAN COURANT NUMBER = 1.130E-04
*** WARNING #007*** SETTING T AT CELL 7501 FROM 8.285E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7502 FROM 5.168E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7503 FROM 3.122E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7701 FROM 8.296E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7702 FROM 5.175E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7703 FROM 3.126E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7901 FROM 8.296E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7902 FROM 5.175E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 7903 FROM 3.126E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8101 FROM 8.296E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8102 FROM 5.175E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8103 FROM 3.126E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8301 FROM 8.296E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8302 FROM 5.175E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8303 FROM 3.126E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8501 FROM 8.285E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8502 FROM 5.168E+04 TO 2.000E+04
*** WARNING #007*** SETTING T AT CELL 8503 FROM 3.122E+04 TO 2.000E+04
Why do these message occurs????????????
My calcualtion informations are - compressible flow - turbuletnt option ON - Courant number is satisfied during simulation - Scalars are ION, ELE, and theses scalars are "active"
Old   July 18, 2005, 06:44
Default Re: Ultra high temperature?
John Luo
You have hit the maximum T limit setting internally in STAR-CD, use Real-Constant 90 to change the set (in Nav-Center, Analysis Controls=>Other Controls=>Switches and Real Constants. After setting R90, write the probe file again (prob).
Old   July 19, 2005, 00:01
bk
Thank you John. I solved my problem about warning message in *.info file. Hmm... How do you know that the R90 means the maximu T limit? And Do you know the meanings of the others Real-Constants?
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
Ultra high temperature case BK Siemens 1 March 4, 2004 03:12
Ultra high Pressure water ? Optixxx FLUENT 0 November 8, 2003 09:21
Why temperature is so high? Albert FLUENT 2 June 22, 2003 11:28
High temperature problem Julie Polyakh Siemens 1 January 5, 2002 16:24
