How to give restart option for transiant analysis
Old   May 7, 2007, 04:12
Default How to give restart option for transiant analysis
Sangamesh
Thank you sir for giving reply
But in transiant analysis we can't give for analysis restart option according to me it is aplicable to only steady state.(as per given user gide )
If i am wrong can you tell me how to give it.
Thanking you.
Old   May 7, 2007, 05:53
Default Re: How to give restart option for transiant analy
Ben
you can do a restart on transient same as on SS providing you have the pst file.
Old   May 10, 2007, 20:45
azmir
Not that simple due to bugs. Sometimes even after setting it to read from restart file, it doesn't work properly. SO, instead I used the star -dp -restart command. And even this sometimes revealed irregularities for case of transient... depends on luck I suppose.
Old   May 21, 2007, 03:24
Sanjay
As stated in the manual an initial field restart is not possible . However a standard restart is easily possible. If you get into errors in starting check whether you have applied the standard restart option before writing out the mdl file and problem file and then you need to restart the run.
analysis restart for lagrangian multiphase mic Siemens 0 July 5, 2007 08:36
problem related to transiant analysis Sangamesh Siemens 3 May 7, 2007 04:09
restart analysis varun Siemens 1 April 22, 2005 23:00
Restart Analysis Bart Siemens 13 January 27, 2005 02:46
restart analysis subhash Siemens 2 September 5, 2002 03:03
