June 6, 2007, 17:34 |
Can I do geometric modeling using STAR-CCM+?
I'm doing an external flow modeling. I can import surface CAD data of a vehicle. To define the outer boundary, I need to add boundaries. Does STAR-CCM+ provide a way to add geometric entities after CAD import? Or do I need to use CAD or ProSurf to define the entire region of the external flow?
Thanks - HK |
June 8, 2007, 06:01 |
Re: Can I do geometric modeling using STAR-CCM+?
CCM+ has not the function on CAD. It's preCAD tool is STAR-DESIGN. In STAR-DESIGN, you can solve your problem easily.
At the same time, CCM+ can import .dba format file. So u can use others CAD tool of star-cd, such as Pro-STAR to generate the far boundary. |
fan modeling in STAR-CCM+ | Martin | Siemens | 2 | December 27, 2010 04:02 |
fan modeling in Star-CD? | donde | Siemens | 2 | October 8, 2008 16:08 |
Solar radiation modeling in Star CCM+ V2 | Vmax | Siemens | 3 | February 27, 2007 05:33 |
Modeling Difficulties using Pro-Star | satish | Siemens | 0 | February 29, 2000 06:14 |
Modeling Difficulties using Pro-Star | satish | Siemens | 0 | February 29, 2000 06:12 |
