thin extrusion meshing
Old   October 27, 2008, 18:39
Default thin extrusion meshing
guillaume
Hi I'd like to know your opinion on what is currently the best tool for meshing thin extrusions: I am modelling a double glazed window and its frame in 3D. The extrusion profile of the frame is fairly complex; it's made up of 2 mm thick aluminium. I'd like to mesh this profile anisotropicaly so that I don't end up with 10 billion cells. It becomes tricky with the fact that there are quite a few different materials in a window, and there are about 100 different interfaces between the different glass/frame materials and the air. The set up of all these interfaces is quite painful. Is there a tool around that could simplify the meshing process of this kind of geometry by offering reasonably anisotropic meshing techniques and automatic interface recognition? Thanks
Old   October 28, 2008, 13:38
Default Re: thin extrusion meshing
user conference
baffles
Old   October 29, 2008, 12:11
Paulh
Old school ProStar; vcex, vfil, vgen, vproj, etc.
HyperMesh
ICEMCFD block mesh
Old   November 4, 2008, 08:53
Phil
In ccm+ you can use the extruder mesher, or you can generate an anisotropic trimmed mesh.
thin extrusion meshing guillaume FloEFD, FloWorks & FloTHERM 1 October 29, 2008 08:10
thin extrusion meshing guillaume Phoenics 0 October 27, 2008 18:39
thin extrusion meshing guillaume Fidelity CFD 0 October 27, 2008 18:39
thin extrusion meshing guillaume FLUENT 0 October 27, 2008 18:38
thin extrusion meshing guillaume Main CFD Forum 0 October 27, 2008 18:36
