posdat user coding
Old   September 1, 2008, 10:37
Default posdat user coding
Sara
Hi. I want to use a subroutine to print pressure and velocity at the end of the simulation at inlet veticies but don't know how to do that. Does anyone can help me? I have problems with the code.
Old   September 16, 2008, 17:46
Default Re: posdat user coding
hirokata
Hi Sara,
Try using 'call FsetBoun' macro in posdat.f, if using v4.06. You can get the inlet boundary faces and obtain pressure and velocity with those face id's. For more info, you can refer to Supplementary Notes.
hirokata
Old   September 17, 2008, 16:02
Sara
thanks for your answer but I'm using v3.26 and I don't find FsetBoun. Thank you again.
Old   September 18, 2008, 13:59
Paulh
Across faces, you can use an internal boundary. After its creation, you can go to 'Monitor Boundary Behavior' and set up a monitor that will export your data per iteration.
VOF user coding Ramki Siemens 2 October 29, 2015 01:07
converting user-coding in V4 Karl Mehler Siemens 0 September 28, 2008 15:48
Print value to screen in user coding? Cb Siemens 1 September 30, 2005 07:29
plz, help me, CFD coding sharuk Main CFD Forum 0 April 6, 2005 05:09
User coding on NT w2k Philip Jones Siemens 0 November 26, 2001 03:43
