I solve the star406.exe or some dll problem(winXP)
Old   December 14, 2008, 21:18
Default I solve the star406.exe or some dll problem(winXP)
MS
Solution
1. Some one got same problem above, might try to remove all the system "Path" list in the s---ing "system variable" in [environmental variable].
!!!!!Caution!!!!!! Before try the solution, make sure you have the f---ing list (already having existed in the system variable) backed up to the notepad or some clip board.
2. Just add really necessary path to execute starCD solver(Most might be under the starCD installed directory tree I think). For this you can check the necessary dll file on the dll missing error message might will pops up after deleting the path in system variable. And their path by using "search" tool in the Windows.
================================================== ==== I guess that the problem caused because of some same name dll files which starCD also provides.
I have terrible english skill so understand as you understand.
Old   January 4, 2009, 21:48
Default Re: I solve the star406.exe or some dll problem(wi
dalit
I got it. Very good solution.
Star406.exe error - 0xc0000142 MS Siemens 1 December 12, 2008 12:56
How to solve this problem liugx212 OpenFOAM Running, Solving & CFD 4 March 21, 2006 10:19
winxp 32 vs 64 tester FLUENT 1 September 22, 2005 12:03
Problem in WinXP wtih V 3.4 & 3.5 Jack bauer Phoenics 3 May 25, 2004 18:47
How can I solve this problem? Lee Siemens 2 September 8, 2003 05:17
