Help on 2D interpolation in StarCCM+
Old   November 3, 2010, 14:21
Default Help on 2D interpolation in StarCCM+
madhuri is on a distinguished road
Hi there,
Iam trying to perform interpolation on 2D data in StarCCM+.
I have used with great success the "InterpolateTable" routine supplied with the software. Essentially it does 1D interpolation of a variable in column2 with respect to variable in column1 of a table.
Iam interested in 2D interpolation where a variable is a function of say Temperature and Pressure. In this case, we would have a 2D table for each variable (say Density). A sample table at few temperatures and pressures is shown below with the real table to be a very large 2D matrix.
T1 T2 T3
P1 0.3 0.4 0.48
P2 0.5 0.53 0.57
P3 0.7 0.87 0.9
Eventually, I need to evaluate Density at any given Temperature and Pressure using interpolation. For simplicity, LINEAR interpolation is sufficient.
I need some suggestions on how to handle such a requirement in StarCCM+. I would really appreciate your help in this regard.
If someone has a work around for this problem, please let me know. Iam not sure if we can write a "user code" for this problem. I have no experience with "user code", but if it solves my problem, I can start working.
Any support from the experience guys will be greatly appreciated.
Sincerely
Madhuri
madhuri is offline   Reply With Quote
Old   May 30, 2017, 03:20
Abhishek Verma
abhiverma16 is on a distinguished road
Hello Madhuri,
I am trying to solve the same problem. Were you able to solve the problem?
Regards
Abhishek VERMA
abhiverma16 is offline   Reply With Quote
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 14:32
[Other] Problems with starccm mesh AndTen OpenFOAM Meshing & Mesh Conversion 1 February 23, 2010 04:43
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
2nd order interpolation for NS solver Quarkz Main CFD Forum 6 July 15, 2005 21:50
