Calculate the heat transfer coeficient of a fin H
Old   February 23, 2009, 08:13
Default Calculate the heat transfer coeficient of a fin H
Christos
Hi all,
I am doing a heat transfer investigation of a fin and i amtrying to find the heat transfer coeeficient. When I select the Hcoef i only get some values of H in the base (which is where i defined the wall-temperature source fixed to 373). The value which i get are very big and they are not making any physical sense. I found somewhere in the forum that i have to do soemthing with the TBULK command in order to set the right temperature reference.
Has anyone done that before?
Kidnest regards
Old   February 23, 2009, 11:23
Default Re: Calculate the heat transfer coeficient of a fi
Pauli
Prostar has two heat transfer coefficients. Are you using "getw, htran" or "getw, hcoef, tbulk"? They can give significantly different results.
Old   February 23, 2009, 12:54
Christos
Many thanks for the reply,
I used both. And any of the output doesnt make sense to me. The other problem is that the calculated values are shown in the wall region ie in the base of the fin and not in the interaction f the fin with the fluid.
Many thanks once again,
regards
Old   February 23, 2009, 16:55
Pauli
I don't know. I've not seen that sort of behavior.
Are your boundary conditions correct? I'd go back and verify the fin and base region definition and settings.
Old   February 23, 2009, 16:56
Christos
Yes i had a look. The heat transfer coeficient is very high both the hcof and the HTC
how to calculate heat transfer coefficient kathiravan Siemens 10 May 5, 2017 16:04
ItsVery Urgent:Pressure,Heat Convection coeficient dev.... FLUENT 3 September 4, 2008 08:11
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 06:33
heat transfer coeficient francois FLUENT 0 June 28, 2005 10:28
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
