Oscillatory flow in a pipe
Old   June 17, 2009, 09:55
Default Oscillatory flow in a pipe
thomas
tom-uk is on a distinguished road
I would like to simulate an oscillatory flow crossing a pipe.
I wonder if I have to use periodic boudaries condition (inlet/outlet) or not?
Also can I use a user fonction to define my flow inlet (like: sin(cst*$Time) )?
Thanks in advance.
Tom
tom-uk is offline   Reply With Quote
Old   June 23, 2009, 07:53
Anton Lyaskin
A_Lyaskin is on a distinguished road
You can use a user defined function BCDEFI to define your inlet, or you can use a table with TIME as independent variable.
As for the outlet, probably you wouldn't need something special, just try with default flow split 1. Or you can try Transient boundary condition, which allow pressure waves escape from the domain, because you'll have some pressure waves.
A_Lyaskin is offline   Reply With Quote
Simulating fully developed flow in a pipe Tim Donohue CFX 1 November 20, 2007 20:24
some weird results about a simple pipe flow: Ning FLUENT 2 March 11, 2007 13:23
Flow through circular curved stationary pipe R.Sripriya Main CFD Forum 0 May 13, 2005 06:07
flow in pipe with momentum and energy source Atit Koonsrisuk CFX 3 March 29, 2005 16:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
