December 5, 2007, 13:21 |
Another breakup model
As I know, there are only three types of breakup model in STAR-CD.(No user subroutine). So, is there any way to apply another breakup model,like WB model thru the user subroutine or any possible way?
December 6, 2007, 04:46 |
Re: Another breakup model
There is a user routine (DROBRK) but it doesn't allow the break-up to generate new parcels, only modify the droplet count.
December 6, 2007, 23:15 |
Thanks for your answer. Richard...
So, you mean I can use only 3 models for breakup and cannot use the other breakup model except those three in Star-CD, right? |
December 7, 2007, 04:02 |
No, there is user coding (DROBRK) but it only allows you to specify d(diameter)/dt, it doesn't allow you to create new parcels, at least not officially or very easily. There are lots of break-up models which you could implement using this method, not just the three internal ones. But you couldn't implement all break-up in this way.
February 14, 2008, 18:48 |
Well in Star-Cd you can use Reitz-Diwakar model, Hsiang-Faeth model and Pilch-Ederman model but you can also try the MPI-1 and MPI-2 models, wich seems to work well on Diesel Sprays...
January 13, 2010, 13:36 |
Rep Power: 17 |
hello, i am trying to model droplet separation in stratified flows (due to KH instability and capillary waves) are the break up model in star cd convenient for this or any other.. i am simulating with cfx...
TAB (Taylor Analogy Breakup) Model | Zi-Wei Chiou | Main CFD Forum | 15 | December 19, 2023 09:27 |
Droplet Breakup | Vinod Dhiman | FLUENT | 1 | October 22, 2010 03:11 |
DPM - breakup postprocessing | bohis | FLUENT | 0 | May 6, 2008 02:58 |
atomization model vs breakup model | Jay | Siemens | 7 | January 24, 2008 19:51 |
breakup model for cleaning processes | Tim | CFX | 2 | November 21, 2007 16:14 |
