Wind Tunnel Contraction Modelling
Like Tree1Likes
  • 1 Post By josh_k
Old   March 28, 2010, 14:20
Post Wind Tunnel Contraction Modelling
Joshua Kanthirao
josh_k is on a distinguished road
I'm using STAR CCM+ to validate and optimize the design of the contraction in a wind tunnel, that I'm designing as a Final Year BE project.
The Wind tunnel:
The tunnel is a blower type with a centrifugal fan at the upstream side. A settling chamber with a honeycomb and six screens (last screen is 40 mesh x 38 SWG or 0.1524mm wire diameter).
The contraction curve uses a fifth order Bell-Mehta polynomial biased by an exponent (alpha)to control the curvatures at the inlet and outlet. Ref: "Transformation of a Polynomial for a Contraction Wall Profile" by Daniel Brassard
The test section has a 300 mm square cross section with a maximum velocity of 30 m/s.
Contraction:
Initially, a contraction ratio of 9 (outlet size: 900 mm square) and a length-to-inlet ratio of 0.8 was used with alpha as 1.0 (equal radius at inlet & outlet). A 45 degree corner chamfer of 25 mm reduces the tendency for secondary flows.
A 5% developing length between the last screen & contraction entry along with a 150 mm developing length after the contraction exit was provided. A 1/8th symmetrical model (imagine the volume between the centreline and a diagonal of a square) was exported as a parasolid and imported into STAR CCM.
Models & Boundary condtions:
A "velocity inlet" (30/9=3.33 m/s) with atmospheric "pressure outlet" was used while the wall and fillet boundaries were specified as "wall" type. The two remaining boundaries were set to "symmetry plane".
For simulating an inlet turbulence level of 2%, the k-omega (SST) turbulence model was used after calculating the value for "k" and the length scale equal to the mesh size of the last screen was used for specifying "omega".
This gave k= 0.006 667 and omega = 117.38
Meshing & Results:
Models used: surface remesher, polyhedra with prism layers
Initial attempt:
Base size: 17 mm (The smallest length, viz. fillet size)
No. of prism layers: 10
Prism layer thickness: 15 mm (absolute)
Surface size: 50% (target) & 20% (minimum)
All other parameters were at their default values.
No. of cells: 112261
Surface integral plots for velocity and average velocity at inlet & exit leveled out completely, close to their expected values in about 50 iterations.
Residuals leveled out (with small oscillations) at about 400 iterations.
Second attempt (checking for grid independence):
Base size: 13 mm
No. of prism layers: 12
Polyhedra: density: 1.2, growth: 0.8
No. of cells: 298339
The problem: When the axial velocity plots were checked at various planes normal to the axis of the contraction, the velocity at few points near the boundary layer edge had velocities close to zero with their neighbours following the general profile.
Therefore, in the next step, the number of prism layers was increased.
Third attempt:
No. of prism layers: 24
Surface size: 50% (target) & 5% (minimum)
Custom surface size for fillet: 10% (target) & 7% (minimum)
Polyhedra: density: 1.0, growth: 1.0
Same problem reoccurs.
I've described this as well as I can and will post the plots when I get back to my lab. If I have left out any data, please let me know.
I'm a CFD novice and would like to know if the meshing/physical model parameters set for the problem are correct or not.
Also, is wall shear stress and skin friction coefficient a good indicator of separation?
Lastly, how do I compare which design gives the least turbulence at the exit? I tried obtaining the turbulence intensity from the "turbulent kinetic energy(Tke)" using a User-defined field function but could not compile the function.
Your feedback would be deeply appreciated.
Thank you
- Joshua Kanthirao,
Don Bosco Institute of Technology, Mumbai
cdunn6754 likes this.
josh_k is offline   Reply With Quote
Old   April 18, 2011, 16:21
Charlie Seviour
CharlieSeviour is on a distinguished road
Thanks for writing out your problem so nicely, you have helped me solve my problem.
My solution was to make a scene with showing the turbulent kinetic energy. Then express the turbulence level I was interested in (10%) as a level of turbulent kinetic energy. This is easily done as the turbulent kinectic energy, k, equals:
3/2*(UI)^2
where U is the velocity and I is the intensity.
If your interested in the sorrounding work, then check out my thesis on my web site:
www.charlieseviour.co.uk
CharlieSeviour is offline   Reply With Quote
contraction, wind tunnel
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
simulate contraction part of wind tunnel fadly CFX 2 July 31, 2007 02:17
contraction part in wind tunnel fadly CFX 0 July 3, 2007 22:33
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
Wind Tunnel Website now online Mike Worthey Main CFD Forum 0 June 6, 2000 02:27
