Need help with the modelling of a leak in a pipe |
October 31, 2015, 16:24 |
Jack
i am a beginner with CFD and i want to make a pipe with a leak in it and i dont have any idea on how to make the leak on the pipe?
do i make a hole in the pipe or what? i tried several ways but they were all bad and i didnt get reasonable solution. do i need to refine my mesh after i do the basic mesh or no need? thank you. |
November 1, 2015, 23:29 |
john
Rep Power: 15 |
Would U please show some pics?
December 27, 2015, 09:16 |
Try 2d first then 3d
SIAN KRISHNA
Rep Power: 10 |
make a pipe of dia 0.5 m and length 5 m. and fill that with fluid ( if you are using design modeller )
then try to make a part extrude at middle of the pipe and m=name it as outlet 2. solve the problem. then go for much more accurate value. if you want any help contact : dimensiondesignanalysis@gmail.com |
modelling heat pipe with VOF | alimondegari | Fluent Multiphase | 0 | May 6, 2014 14:36 |
Extraction of 3D hollow pipe from 3d solid pipe | jr33 | Main CFD Forum | 1 | September 24, 2012 15:06 |
[GAMBIT] Meshing a pipe | vedravi | ANSYS Meshing & Geometry | 1 | March 25, 2010 13:19 |
pipe in pipe heat exchanger | JohannV | FLUENT | 3 | December 3, 2009 02:53 |
CYCLIC BC in pipe flows | matthias | OpenFOAM | 0 | November 5, 2009 10:52 |
