December 14, 2015, 17:46 |
Advice on simulating gas filternig system
Kohbodi
Rep Power: 10 |
Hi everyone,
Basically I am looking so simulate gas filtering through a liquid based on the pressure applied. You can imagine this as a scrubber system (air pollution control devices) hookahs, inhalers, etc... I am using OpenFoam and pretty new to it but have a solid grasp of it. I was thinking of using similar to interFoam? Not sure how I can simulate pressure applied causing air to go through the liquid (bubbling, filtering?). Are there previous work on this topic through the use of OpenFoam? Should I use Ansys Fluent in this case? Any help is much appreciated. Thank you |
June 17, 2016, 06:48 |
Christian
Rep Power: 12 |
Hi Kohbodi,
you could try the following BCs at inlet to make air particles enter the fluid. BCs for inlet: - pressure: 'totalPressure - velocity: 'pressureInletVelocity' more then interFoam, I would look for extensions of it such us bubbleFoam or similar. If you need some help let me know or please write me in private. Christian |
the incompressible idea gas law in natural convection | hotboy | FLUENT | 1 | June 22, 2015 21:02 |
Need advice on softwares working for dilute gas flow | Mason | Main CFD Forum | 4 | July 22, 2010 15:55 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
allowed gas phase escape | Abu-Khawlah | FLUENT | 0 | August 20, 2005 10:14 |
advice needed in solving linear system | yf yap | Main CFD Forum | 5 | February 5, 2001 00:21 |
