March 16, 2016, 08:19 |
Help with my errors ANSYS fluent
anonymous
HI.
basically it is a scale model on a cylindrical waste water trap. It will get water in at .5l/s 1l/s and 2l/s. the top should be a pressure outlet as it is open. I should be able to later represent the vortex of the water and get results about how the sediment soil sit at the bottom. And in another test see how oil will act in the model as well (if it sticks to the sand and sits at the bottom) Im not sure if i can test that with ansys though. I will get the head loss, velocity profiles, head loss coefficient, The main purpose for it is to remove contaminants from waste water so: 1) i need double precision at the moment it gives error "The fl process could not be started" at about 1500 - 5000 iterations. 2) stop it giving reverse flow in the iterations (due to top being pressure outlet) 3) Help with how to extract results and characteristics for sediments, water and oil basically i need help to solve these errors and somebody to tutor me on the problems i have. I don't need you to do the work for me, just help me trouble shoot and give me advice as i want to learn. we can chat via skype etc. |
March 20, 2016, 05:26 |
Kuldeep
Rep Power: 10 |
Hi!!
I can resolve your issues. You can write to me on my mail id ksingh[at]tserc[dot]in |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 06:10 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
