Very small job: converting an OpenFOAM mesh to a format needed by another code |
June 11, 2016, 16:08 |
Rep Power: 9 |
I need to run a benchmark to compare a result based on OpenFOAM/interFoam with a result from another code.
I'd like to use a mesh that is similar for both codes. The other code does not have a great meshing tool, so I'd like to export the OpenFOAM mesh in a form that can be used by the other code. The file attached here, "mesh.txt" shows an example format of a mesh for the other code. This kind of thing is not straightforward for me, but maybe there's someone out there who would find it easy to do. If you're interested, please PM me and I can provide any further details, including my OpenFOAM mesh. Thank you. |
June 24, 2016, 05:45 |
Jon
TS might be able to help.
What is the other code? We have converted OpenFOAM meshes into formats most commercial codes can read. Email us if you have not already sorted it. info@totalsim.co.uk |
mesh, mesh 2d, mesh adaptation, mesh adaption, mesh and grid |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
[Commercial meshers] converting Ensight gold format mesh to OF | Kossivi | OpenFOAM Meshing & Mesh Conversion | 1 | June 6, 2020 01:39 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
Converting a Fluent Mesh with Porous Jump into OpenFOAM mesh with porousBaffle | billwangard | OpenFOAM Pre-Processing | 1 | February 19, 2015 09:07 |
[Other] How to convert a mesh into openfoam format | jr33 | OpenFOAM Meshing & Mesh Conversion | 1 | October 2, 2012 17:20 |
