November 19, 2016, 06:34 |
Which air properties?
Rep Power: 9 |
I am stuying non equilibrium thermal model. System inlet temperature constant at 1473 Kelvin. System initial temperature at 300 Kelvin. My question is Which air temperature properties I should use? (1473 Kelvin or 300 Kelvin or average.) I added picture of system and. I added picture of system temperature change in transient solution. Thank you in advance. Best Regards. |
November 21, 2016, 00:53 |
May Be you should try using temperature dependent properties for air.
November 21, 2016, 03:10 |
#3 | |
Rep Power: 9 |
System initial temperture 300K. and when finish the charging. Solid and fluid temperature reach 1473K. Best Regards. |
November 21, 2016, 08:41 |
#4 | |
Kushal Puri
Rep Power: 12 |
You need to define some polynomial curves. |
Humid air properties | surya.madugula | STAR-CCM+ | 17 | January 23, 2017 13:34 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Variation of air properties with altitude | saisanthoshm88 | Main CFD Forum | 1 | June 8, 2012 07:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
