April 8, 2020, 06:53 |
dynamic, physics-driven mesh
Misha
Rep Power: 7 |
Hello all,
I'm looking for someone to help with a simulation I want to run. The simulation consists of a mesh that encompasses the surrounding air, a static object (henceforth called shroud), and a dynamic rotating mesh of an object (henceforth called rotor), that is driven by the airflow passing through the rotor. I am interested in running several cases - several different geometries for the shroud and rotor, as well as different air flow velocities and incident angles. A 3D mesh would be great, but a 2D mesh will suffice. Best regards, Mikhail |
April 9, 2020, 12:01 |
Reply to (dynamic, physics-driven mesh)
AboAhmad
Rep Power: 11 |
All praise is due to Allah
I am a TA in aerospace engineering, I have a lot of experience in Ansys Fluent for more than 10 years, in different applications including turbo-machines, please let me know how I can help you? you can send to aerospacelab20@gmail.com best wishes |
April 20, 2020, 00:42 |
Fluid Tool Engineering
Rep Power: 6 |
I am interested in this project. You can contact me via email: fluidtool(at)gmail.com. You can find more information at website: https://fluidtool.com/ You can send me the detailed scope with geometry and conditions,and will discuss in detail further. Thanks Fluid Tool Engineering |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 15:08 |
Dynamic gradient mesh adaption not working properly | MarkelRF | FLUENT | 0 | August 28, 2018 05:19 |
Sliding / Dynamic Mesh in heat transfer problem | platzhalter | FLUENT | 0 | May 7, 2018 05:25 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
