Flow through pipe bend tutorial - Solver Error
Old   May 15, 2012, 13:14
Default Flow through pipe bend tutorial - Solver Error
Andrew Smith
sledfreak17 is on a distinguished road
Anyone have any ideas of what the issue could be?
sledfreak17 is offline   Reply With Quote
Old   May 15, 2012, 19:35
Sounds pretty obvious. You do not have a valid definition file. This is probably because of a problem in CFX-Pre so it did not generate a def file and the rest of the workbench system failed to execute because of it.
Old   May 16, 2012, 09:44
Andrew Smith
Thanks,
To be more specific, this is the problem in CFX-pre:
Old   May 16, 2012, 10:04
Lance
Lance is on a distinguished road
The error says that you have specified two boundary conditions at the same location (inlet). Why not change it?
Lance is offline   Reply With Quote
Old   May 16, 2012, 10:29
Andrew Smith
The intention was obviously not to specify two boundary conditions at the inlet,
there is no-slip at the walls, symmetry of the side faces and inflow and outflow boundary conditions specified.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
