Blood flow in aorta
Like Tree1Likes
Old   April 20, 2011, 06:56
Default Blood flow in aorta
Marko Milasinovic
milasko is on a distinguished road
Hello. I need to determine physical dimensions of blood flow in abdominal aorta. Can you tell me how to insert profile velocity in function of time as inlet boundary? I attached velocity function of time.
milasko is offline   Reply With Quote
Old   April 20, 2011, 18:58
A user function with a 1D interpolation will do it easily.
Old   April 21, 2011, 04:11
Marko Milasinovic
Can you describe how to do it?I started recently to use CFX.
Old   April 21, 2011, 11:33
Default Function
Govindaraju
kmgraju is on a distinguished road
Dear friend
I am also doing the same problem .
I want to know how did you get the graph?
what function did you use to get the graph?
I also need this answer. please give your answer if you find.
Thank you
Govind
kmgraju is offline   Reply With Quote
Old   April 22, 2011, 11:22
Ugly Kid Joe
vmlxb6 is on a distinguished road
This should help you out:
http://www.edr.no/blogg/ansys_blogge...nsient_profile
Regards
vmlxb6 is offline   Reply With Quote
Old   April 22, 2011, 12:25
Marko Milasinovic
My professor is working with vascular problems. He measured blood velocity in coronal arthery. I adjusted his values for my problem.
Old   April 26, 2011, 06:35
Govindaraju
Dear milasko
How your professor got the values .what function did he use for getting number of values.
if he uses any function like sin or cos please let me know.I need it urgently. I assume that without a function cannot get number values . am I right?
what equation did he use to plot the graph?
Thank you
kmgraju
Old   April 26, 2011, 11:32
Marko Milasinovic
I think that he performed examing on the pacient.I didn`t ask.The reason is that he is not at my department, I took exam because I earlier worked in FLUENT some simple cases.
Old   July 2, 2011, 07:14
Marko Milasinovic
I fill out csv file format for profile boundary condition. when I try to initialise profile data I receive error "Invalid data heading seen in profil `ulaz` at line 8. Between 1 and 3 spatial field names must be specified." Can you tell me what is wrong? I attached picture of profile boundary condition.
Old   July 4, 2011, 02:33
Lance
Lance is on a distinguished road
"Between 1 and 3 spatial field names must be specified."
You specify X,Y,Z,t == 4 "spatial" fields. If you want to include time you must remove one of the spatial fields.
Lance is offline   Reply With Quote
Old   July 4, 2011, 04:41
Marko Milasinovic
Ok.I understand. I didn`t know that I can`t specify more than 3 fields.Thanks a lot.
Old   February 7, 2012, 16:38
Lauren Dransfield
ld1305 is on a distinguished road
I realise this is a few months old, but was wondering about something similar, I've looked through the website that was suggested and wondered what the spacial fields actually represent? At the moment I just have time and velocity
ld1305 is offline   Reply With Quote
Old   February 8, 2012, 03:00
Marko Milasinovic
Spatial fields have function to identify nodes positions to which you have dedicate velocity
Old   February 8, 2012, 10:07
Lauren Dransfield
That makes sense and is what I suspected anyway, but when I run my simulation it seems to not let me view more than one time-step, I only have 0, though the function file I made says it should last 1 second, do you know how I'd fix this so I could view it at different points within my 1 second?
Old   February 8, 2012, 12:07
Marko Milasinovic
Take a look on 5th post.You would notice that you need to set different time value for other steps
Old   February 8, 2012, 12:18
Lauren Dransfield
Do you mean different values as in:
this
Old   February 8, 2012, 13:33
Marko Milasinovic
Yes, like that
Old   February 8, 2012, 13:36
Lauren Dransfield
I had done that before, what I'm asking is if there is a way to view the fluid at say the first time-frame and the last, similar to the example in the 5th post? I can't find this...
Old   February 9, 2012, 11:08
Marko Milasinovic
you need to perform calculation and after that using CFD-Post you can see fluid velocities
Old   February 9, 2012, 18:42
Shashwat
shaswat is on a distinguished road
Hi
Is your flow in the x direction?
shaswat is offline   Reply With Quote
Pulsatile blood flow John H FLUENT 7 March 3, 2022 07:50
Modeling blood flow - FloWorks mcneelyd FloEFD, FloWorks & FloTHERM 2 June 15, 2009 12:53
FLUENT BLOOD FLOW RATE Christoforos FLUENT 0 September 18, 2008 10:08
3D pulsatile blood flow UDF Michal Main CFD Forum 0 February 25, 2005 07:18
Fluent blood flow BC Michal Main CFD Forum 3 February 17, 2005 03:17
