July 24, 2012, 07:43 |
CFX result file to Tecplot
mistry
Rep Power: 17 |
Dear friends,
I was using CFX post processor for my results of CFD analysis but for near wall region in turbo machines i would like to plot 1-D,2-D velocity plot. which i found not possible with CFX Post processor.I heard it is possible with Tecplot. but i have no idea how to use Tecplot for cfx results. i made cgns file too. still i face problem. can you suggest something? |
July 24, 2012, 19:41 |
Rep Power: 143 |
What aer you trying to do? CFD-Post is a powerful post processor and there is not much it cannot do.
July 28, 2012, 06:33 |
mistry
Rep Power: 17 |
I would like to capture flow physics in tip region (Between casing and rotor) in terms of velocity vector along the camber .
I am sure you will surely suggest some idea!! |
July 28, 2012, 07:50 |
Rep Power: 143 |
CFD-Post has many tools and should be able to do what you describe. Can you describe exactly what you intend to do? An image would help.
July 29, 2012, 05:48 |
mistry
Rep Power: 17 |
Please look at the plots and kindly suggest me how to plot it.
July 29, 2012, 07:29 |
Rep Power: 143 |
Doesn't these plots already show the velocity vectors in the tip region? What further views do you want to see?
August 8, 2012, 09:59 |
mistry
Rep Power: 17 |
Sir, this plots are by StarCD software. I want to have it in CFX Turbo...!!!
August 10, 2012, 08:17 |
Tecplot
Rep Power: 15 |
Tecplot 360° 2012 supports Ansys CFX. If you're lucky enough to have this last version you should import your results without problems. However, if you have an older version, you should export your results in Ensight format (I think...)
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
