Simulation of adsorption by using CFX
Old   September 11, 2012, 07:02
Default Simulation of adsorption by using CFX
Xiaolei
essjcx is on a distinguished road
Dear All,
I am quite new to CFX and trying to simulate the adsorption process on carbon nanofibre in liquid phase (one organic specie in water and the organic specie can be adsorbed on carbon surface).
I am now stuck with how to set up equilibrium for this adsorption process. Does anybody have relevant information on this case?
I am currently specifying sources terms for the species on the boundary (I used a wall boundary represent the carbon fibre). But this cannot represent the equilibrium process in physical system.
Thank you very much in advance.
Best regards,
Xiaolei
essjcx is offline   Reply With Quote
Old   September 11, 2012, 07:19
Before you can set anything up like this you need to know the mathematics which describe it. You cannot do much (except random guesses) without knowing the maths.
What is the mathematics of the model you wish to introduce?
Old   September 11, 2012, 07:28
Xiaolei
Thank you for the reply, ghorrocks.
The mechnism is: A + surface <--> Asurface and this is a reversible process (reaction). The Kforward and Kbackward are available. Would you please recommend how to set up a reaction model for setting up the equlibrium of transfering the A in liquid phase to solid phase?
Thank you very much!
Old   September 11, 2012, 07:30
You can probably do this with additional variables and source terms, but it might be easier to use the chemistry model to do it. There are some examples of chemistry modelling in the CFX tutorials, and CFX support has more available.
Old   September 17, 2012, 03:31
Jovan
Jovan10 is on a distinguished road
Hi ghorrocks and Xiaolei,
I am also modelling a similar situation (except mine is sugar adsorption onto an activated silica surface). The method I am employing is similar to the one that was mentioned by Xiaolei, in that I have added an additional variable and source terms.
Ghorrocks, when you mention the chemistry modelling tutorial, which one are you referring to? Also, would this actually be a better way to model the problem?
Jovan10 is offline   Reply With Quote
Old   September 17, 2012, 04:40
Xiaolei
Hi Jovan10,
I think Ghorrocks refers to the acid and base mixing-reacting problem in CFX tutorial. In that tutorial, the reaction rate was specified according to the eddy dissipation model since the problem is turbulence and the reactuon source terms were introduced by simply timing the mass fraction with the rate. I do not think this tutorial is a good example for our adsorption problem because there is no equilibrium described. I can do the adsorption with FLUENT but now I am thinking how to do this wil CFX.
We can chat on this based on the nature of our problem. Let me know.
Cheers,
Xiaolei
Old   September 21, 2012, 00:56
Jovan
Hi Xialoei,
Yes I too have realised that it is easier to model adsorption on Fluent rather than CFX.
The way I have gone about it at this point in time is to just define a basic sink term, but I am unsure on how to model the transfer of the solute to the adsorbent.
I have the same issue as you, and am new to CFX.
Best regards,
Jovan
Old   May 15, 2014, 04:24
Micheal is on a distinguished road
Hi xiaolei
I am now facing the similar problem ,I have to simulate the adsorption and desorption process silica-gel water with FLUENT,but now I don't know how to set the model,can you give me some practical advice.Thank you very much.
Micheal
Micheal is offline   Reply With Quote
Old   April 16, 2020, 03:03
Default alireza
alireza javadpour
alireza7246 is on a distinguished road
hi xiaolei
i am also modeling water vapor adsorption by silica gel with Fluent, but i cant model adsorption and i dont know how to write UDF code and other setting parameters in Fluent, please help me
alireza7246 is offline   Reply With Quote
Old   April 16, 2020, 03:06
Try the Fluent forum. This is the CFX forum.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
CFX vs FLUENT for particle tracking simulation iman ANSYS 2 August 31, 2012 20:34
nucleate boiling simulation in CFX Anil CFX 3 August 25, 2010 14:18
Small cluster configuration for pump simulation at CFX Nevel CFX 3 February 3, 2010 22:37
2D simulation - ICEM meshing for CFX question Ben Makhal CFX 5 April 11, 2007 08:44
Simulation of turbine cascade in CFX. Jonas Pedro Caumo CFX 0 December 9, 2006 13:54
