September 11, 2012, 07:02 |
Simulation of adsorption by using CFX
Xiaolei
Rep Power: 13 |
Dear All,
I am quite new to CFX and trying to simulate the adsorption process on carbon nanofibre in liquid phase (one organic specie in water and the organic specie can be adsorbed on carbon surface). I am now stuck with how to set up equilibrium for this adsorption process. Does anybody have relevant information on this case? I am currently specifying sources terms for the species on the boundary (I used a wall boundary represent the carbon fibre). But this cannot represent the equilibrium process in physical system. Thank you very much in advance. Best regards, Xiaolei |
September 11, 2012, 07:19 |
Rep Power: 143 |
Before you can set anything up like this you need to know the mathematics which describe it. You cannot do much (except random guesses) without knowing the maths.
What is the mathematics of the model you wish to introduce? |
September 11, 2012, 07:28 |
#3 | |
Xiaolei
Rep Power: 13 |
The mechnism is: A + surface <--> Asurface and this is a reversible process (reaction). The Kforward and Kbackward are available. Would you please recommend how to set up a reaction model for setting up the equlibrium of transfering the A in liquid phase to solid phase? Thank you very much! |
September 11, 2012, 07:30 |
Rep Power: 143 |
You can probably do this with additional variables and source terms, but it might be easier to use the chemistry model to do it. There are some examples of chemistry modelling in the CFX tutorials, and CFX support has more available.
September 17, 2012, 03:31 |
#5 | |
Jovan
Rep Power: 13 |
I am also modelling a similar situation (except mine is sugar adsorption onto an activated silica surface). The method I am employing is similar to the one that was mentioned by Xiaolei, in that I have added an additional variable and source terms. Ghorrocks, when you mention the chemistry modelling tutorial, which one are you referring to? Also, would this actually be a better way to model the problem? |
September 17, 2012, 04:40 |
#6 | |
Xiaolei
Rep Power: 13 |
Hi Jovan10, I think Ghorrocks refers to the acid and base mixing-reacting problem in CFX tutorial. In that tutorial, the reaction rate was specified according to the eddy dissipation model since the problem is turbulence and the reactuon source terms were introduced by simply timing the mass fraction with the rate. I do not think this tutorial is a good example for our adsorption problem because there is no equilibrium described. I can do the adsorption with FLUENT but now I am thinking how to do this wil CFX. We can chat on this based on the nature of our problem. Let me know. Cheers, Xiaolei |
September 21, 2012, 00:56 |
Jovan
Rep Power: 13 |
Hi Xialoei,
Yes I too have realised that it is easier to model adsorption on Fluent rather than CFX. The way I have gone about it at this point in time is to just define a basic sink term, but I am unsure on how to model the transfer of the solute to the adsorbent. I have the same issue as you, and am new to CFX. Best regards, Jovan |
May 15, 2014, 04:24 |
Hi xiaolei
I am now facing the similar problem ,I have to simulate the adsorption and desorption process silica-gel water with FLUENT,but now I don't know how to set the model,can you give me some practical advice.Thank you very much. Micheal |
April 16, 2020, 03:03 |
alireza
#9 |
alireza javadpour
Rep Power: 7 |
hi xiaolei
i am also modeling water vapor adsorption by silica gel with Fluent, but i cant model adsorption and i dont know how to write UDF code and other setting parameters in Fluent, please help me |
April 16, 2020, 03:06 |
#10 |
Rep Power: 143 |
Try the Fluent forum. This is the CFX forum.
CFX vs FLUENT for particle tracking simulation | iman | ANSYS | 2 | August 31, 2012 20:34 |
nucleate boiling simulation in CFX | Anil | CFX | 3 | August 25, 2010 14:18 |
Small cluster configuration for pump simulation at CFX | Nevel | CFX | 3 | February 3, 2010 22:37 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
