Adaptive timestep
Old   November 12, 2012, 04:21
Default Adaptive timestep
siw
Stuart
siw will become famous soon enough
Glenn posted some information about using the adaptive timestep for a transient simulation when the timestep is not known beforehand (http://www.cfd-online.com/Forums/cfx...e-problem.html). I need to do the same.
However, in the other topic it is not clear to me were the mentioned coefficient loops are input (analysis type or solver control - see images) since I've tried and they don't like being the same. So in which should the recommend 3-5 be input?
Also, what's the reason for assessing the influence of convergence tolerance? I always set my simulations to a residual target = 1E-06 or lower and let the solver keep iterating until it reaches whatever values it gets too with enough iterations to observe either constant residual values (steady flow) or oscillating residual values (unsteady flow). Then there's no need to assess this parameter.
Thanks.
siw is offline   Reply With Quote
Old   November 12, 2012, 18:53
Erik
evcelica is on a distinguished road
Analysis type is where you would set up your adaptive time-steps. Solver control is where you would set your convergence criteria and min/max number of time-steps per loop. The timestep will be adapted to try to meet your convergence criteria in 3-5 timesteps, but will never go over 10, or under 1, (or whatever you have set in solver control)
1E-6 might not be possible in some simulations, or may be terribly inefficient for some transient runs. But it sounds like you are talking about a steady state simulation in your last sentence?
evcelica is offline   Reply With Quote
Old   November 13, 2012, 02:19
siw
Stuart
I applied those data from Glenn's post as I thought he was detailing and it has greatly improved all the convergences, compared to the pre-cursor steady-state run (200 iterations) which I used for establishing an initial flowfield. When looking at the *.out file on the last few iterations (which would done for only 3 coeff loops) the solver found at timestep size (2.1074E-08 s). Is it now better practice to continue over the next few thousand iterations using this constant time step?
I was suprised not to see oscillations in the monitor points though. The simulation is a transonic aerodynamic flow behind some bluff bodies, so I'm expecting unsteady behaviour. Next I'm going to keep everything the same but use SAS-SST rather than URANS-SST.
My last sentance was just about why would anyone assess the convergence tolerance when all I do is set it really low.
Old   November 13, 2012, 11:28
Erik
You set it "really low" which is causing your timestep to have to get extremely small to meet that convergence criteria. If you were to set your convergence criteria higher you could solve it in much much less time. Then you can change your convergence criteria which would also change your timestep size and you would be checking for convergence and timestep independance.
Your idea of just "setting it really low" is just innefficient.
Also 10^-6 RMS may not be good enough for some types of flows, or may be unattainable for others, meaning your adaptive timestepping would keep on decreasing and decreasing and roundoff errors start to effect the solution.
I would leave the timestepping on adaptive if you are going to run more iterations, there will be times in unsteady flow where a larger timestep can be used and other times when a smaller timestep has to be used; let the solver adapt itself to the flow.
Adaptive Timestep and Residuals siw CFX 6 August 23, 2012 02:21
questions about sensitivity analysis and adaptive timestep sjtusyc CFX 10 June 21, 2012 09:24
Adaptive Timestepping: Possible Glitch? Josh CFX 9 August 25, 2010 21:52
ANSYS CFX Adaptive Timestep aeroman CFX 8 July 25, 2009 06:37
ANSYS CFX Adaptive Timestep aeroman Main CFD Forum 1 July 23, 2009 19:53
