Conjugate Heat Transfer
Old   January 2, 2013, 13:30
Smile Conjugate Heat Transfer
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello every one
I am trying to simulate conjugate heat transfer from fluid to adjacent wall of thickness 5mm how to model this in CFX.or how to generate expression for wall conduction is there any tutorial to solve these type of problems
Thank you
sunilpatil is offline   Reply With Quote
Old   January 2, 2013, 13:31
Smile Matlab Program input
sunilpatil's Avatar
sunil
Hello everyone
Is it possible to take matlab program as a input in CFX
Old   January 2, 2013, 14:32
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
For CHT, try the "Heat Transfer from a Heating Coil" tutorial problem.
Matlab could be used to CCL files if you want to run a bunch of cases varying certain parameters, although this is probably more effectively done using a script. In theory you should also be able to call cfx5solve from Matlab, but I've never tried this so I can't help you with it. Again, a script would be a more obvious choice for this, but it depends on what you are doing if you need Matlab for some reason.
cdegroot is offline   Reply With Quote
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 10:44
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
