Water subcooled boiling
Old   June 8, 2011, 13:12
Default Water subcooled boiling
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Dear CFX users,
I have troubles with boiling simulation in CFX. The main problems are that the solver crashes when vapour generates and until crash (30-40iterations) the vapour temperatures grows up to 300000 K.
I have used the default empirical terms for the boiling phenomena. The water jacket inside pressure is 6 bar, inlet temperature 85 C, wall temperature 180 degrees. Material: IAPWS water and steam, where the saturation temperature is given in tables.
Any suggestion about the used models, boundaries are welcome.
Thank you in advance,
Attila
LIBRARY:
CEL:
EXPRESSIONS:
Gravity = -9.81[m s^-2]
InletTemp = 86 [C]
MaxAbsPress = OutPress+1 [atm]
OutPress = 5 [bar]
SaturationTemperature = Function Saturation(Absolute Pressure)
SurfaceTensionCoefficient = 10^-3*Function \
SurfaceTensionCoefficient(Water.T)
TempBoresValveplate = 200 [C]
TempHousingValveplate = 150 [C]
WallHeatTemp = 220 [C]
END
FUNCTION: Function Saturation
Argument Units = bar
Option = Interpolation
Result Units = C
INTERPOLATION DATA:
Data Pairs = \
0.006112,0.01,0.012271,10.00,0.023368,20.00,0.0424 17,30.00,0.073749\
,40.00,0.12334,50.00,0.19919,60.00,0.31161,70.00,0 .47359,80.00,0.70\
108,90.00,1.0132,100.00,1.4326,110.00,1.9854,120.0 0,2.7012,130.00,3\
.6136,140.00,4.7597,150.00,6.1804,160.00,7.9202,17 0.00,10.003,180.0\
0,12.552,190.00,15.551,200.00,19.08,210.00,23.201, 220.00,27.979,230\
.00,33.48,240.00,39.776,250.00,46.94,260.00,55.051 ,270.00,64.191,28\
0.00,74.448,290.00,85.917,300.00,98.697,310.00,112 .9,320.00,128.65,\
330.00,146.08,340.00,165.37,350.00,186.74,360.00,2 10.53,370.00,221.\
2,374.15
Extend Max = No
Extend Min = No
Option = One Dimensional
END
END
FUNCTION: Function SurfaceTensionCoefficient
Argument Units = C
Result Units = N m^-1
INTERPOLATION DATA:
Data Pairs = \
0.01,75.6,10,74.24,20,72.78,30,71.23,40,69.61,50,6 7.93,60,66.19,70,\
64.4,80,62.57,90,60.69,100,58.78,110,56.83,120,54. 85,130,52.83,140,\
50.79,150,48.7,160,46.59,170,44.44,180,42.26,190,4 0.5,200,37.81,210\
,35.53,220,33.23,230,30.9,240,28.56,250,26.19,260, 23.82,270,21.44,2\
80,19.07,290,16.71,300,14.39,310,12.11,320,9.89,33 0,7.75,340,5.71,3\
50,3.79,360,2.03,370,0.47,374.15,0,380,0
Extend Max = On
Extend Min = No
END
END
END
MATERIAL: Aluminium EN AC 46000
Material Group = CHT Solids
Option = Pure Substance
Thermodynamic State = Solid
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 2650 [kg m^-3]
Molar Mass = 26.98 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 910 [J kg^-1 K^-1]
END
REFERENCE STATE:
Option = Specified Point
Reference Specific Enthalpy = 0 [J/kg]
Reference Specific Entropy = 0 [J/kg/K]
Reference Temperature = 25 [C]
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 120 [W m^-1 K^-1]
END
END
END
MATERIAL: Cast Iron GG25
PROPERTIES:
EQUATION OF STATE:
Density = 7870 [kg m^-3]
Molar Mass = 55.85 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 460 [J kg^-1 K^-1]
END
REFERENCE STATE:
END
Option = Value
Thermal Conductivity = 48.5 [W m^-1 K^-1]
END
END
END
MATERIAL: IAPWS STEAM
Material Group = IAPWS IF97,Interphase Mass Transfer,Water Data
Thermodynamic State = Gas
PROPERTIES:
Option = IAPWS Library
REFERENCE STATE:
Option = Automatic
END
TABLE GENERATION:
Maximum Absolute Pressure = MaxAbsPress*1.1
Maximum Points = 200
Maximum Temperature = WallHeatTemp*1.5
Minimum Absolute Pressure = 0.5 [atm]
Minimum Temperature = InletTemp*0.9
Pressure Extrapolation = On
Temperature Extrapolation = Yes
END
END
END
MATERIAL: IAPWS WATER
Thermodynamic State = Liquid
PROPERTIES:
REFERENCE STATE:
Option = Automatic
END
TABLE GENERATION:
Maximum Absolute Pressure = 2.5 [atm]
Maximum Temperature = 550 [K]
Minimum Temperature = 350 [K]
END
END
END
MATERIAL: Steel
PROPERTIES:
EQUATION OF STATE:
Density = 7854 [kg m^-3]
Option = Value
END
Option = Value
Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1]
END
REFERENCE STATE:
END
Option = Value
Thermal Conductivity = 60.5 [W m^-1 K^-1]
END
END
END
MATERIAL: Water Glycol
Material Group = User
PROPERTIES:
EQUATION OF STATE:
Density = 1045 [kg m^-3]
Molar Mass = 40.9 [kg kmol^-1]
Option = Value
END
Option = Value
Specific Heat Capacity = 3490 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 0.00105 [Pa s]
Option = Value
END
Option = Value
Thermal Conductivity = 0.39 [W m^-1 K^-1]
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: FLUID_WATERJACKET
Coord Frame = Coord 0
Domain Type = Fluid
Location = TET_FLUID
BOUNDARY: FLUID_ADIABATIC
Boundary Type = WALL
Location = INTER_WJ_SUPERCOOLING_GASKET_UPPER
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL CONTACT MODEL:
Option = Specify Area Fraction
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
FLUID PAIR: Vapour | Water
WALL ADHESION:
Option = None
END
WALL BOILING MODEL:
Bubble Diameter Influence Factor = 2.0
Fixed Yplus for Liquid Subcooling = 250.0
Mass Source Under Relaxation = 0.1
Maximum Area Fraction of Bubble Influence = 0.5
Option = RPI Model
BUBBLE DEPARTURE DIAMETER:
Liquid Subcooling Scale = 45.0 [K]
Maximum Departure Diameter = 1.4E-3 [m]
Option = Tolubinski Kostanchuk
Reference Departure Diameter = 0.6E-3 [m]
END
BUBBLE DETACHMENT FREQUENCY:
Drag Coefficient = 1.0
Option = Terminal Velocity over Departure Diameter
END
BUBBLE WAITING TIME:
Option = Proportional to Detachment Period
Waiting Time Fraction = 0.8
END
LIQUID QUENCHING HEAT TRANSFER COEFFICIENT:
Option = Del Valle Kenning
END
WALL NUCLEATION SITE DENSITY:
Option = Lemmert Chawla
Power Law Index = 1.805
Reference Nucleation Site Density = 7.9384e5 [m^-2]
Reference Wall Superheat = 10.0 [K]
END
END
END
END
FLUID: Vapour
WALL CONTACT AREA:
Area Fraction = 0
Option = Area Fraction
END
END
END
FLUID: Water
WALL CONTACT AREA:
Area Fraction = 1
END
END
END
END
BOUNDARY: FLUID_WATERJACKET Default
Location = Primitive 2D,Primitive 2D A,Primitive 2D B,Primitive 2D \
C,Primitive 2D D,Primitive 2D E,Primitive 2D F,Primitive 2D \
G,Primitive 2D H,Primitive 2D I,Primitive 2D J,Primitive 2D \
K,Primitive 2D L,Primitive 2D M
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
Option = Fluid Dependent
END
WALL CONTACT MODEL:
END
WALL ROUGHNESS:
END
END
WALL ADHESION:
Option = None
END
WALL BOILING MODEL:
Option = RPI Model
END
END
END
END
END
END
END
END
FLUID: Vapour
MASS AND MOMENTUM:
END
WALL CONTACT AREA:
Area Fraction = 0
END
END
END
FLUID: Water
MASS AND MOMENTUM:
END
WALL CONTACT AREA:
Area Fraction = 1
END
END
END
END
BOUNDARY: INLET
Boundary Type = INLET
Location = WATER_INLET
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = InletTemp
END
MASS AND MOMENTUM:
Mass Flow Rate = 0.24383 [kg s^-1]
Option = Bulk Mass Flow Rate
END
TURBULENCE:
Eddy Length Scale = 0.03 [m]
Fractional Intensity = 0.05
Option = Intensity and Length Scale
END
END
FLUID: Vapour
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END
END
END
FLUID: Water
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END
END
END
END
BOUNDARY: OUTLET
Boundary Type = OUTLET
Location = WATER_OUTLET
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
Relative Pressure = OutPress
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
BOUNDARY: PIPES
Location = WATER_INLET_PIPE,WATER_OUTLET_PIPE
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
END
WALL CONTACT MODEL:
Option = Use Volume Fraction
END
WALL ROUGHNESS:
END
END
WALL ADHESION:
Option = None
END
END
END
END
BOUNDARY: WallHeated
Location = INTER_WJ_VALVEPLATE
HEAT TRANSFER:
Fixed Temperature = WallHeatTemp
Option = Fixed Temperature
END
MASS AND MOMENTUM:
END
WALL CONTACT MODEL:
END
WALL ROUGHNESS:
END
END
WALL ADHESION:
Option = None
END
WALL BOILING MODEL:
Option = RPI Model
END
END
END
END
END
END
END
END
FLUID: Vapour
MASS AND MOMENTUM:
END
WALL CONTACT AREA:
Area Fraction = 0
END
END
END
FLUID: Water
MASS AND MOMENTUM:
END
WALL CONTACT AREA:
Area Fraction = 1
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Buoyancy Reference Density = 0.5974 [kg m^-3]
Gravity X Component = 0 [m s^-2]
Gravity Y Component = 0 [m s^-2]
Gravity Z Component = Gravity
Option = Buoyant
BUOYANCY REFERENCE LOCATION:
Option = Automatic
END
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID DEFINITION: Vapour
Material = IAPWS STEAM
Option = Material Library
MORPHOLOGY:
Mean Diameter = 0.6 [mm]
Option = Dispersed Fluid
END
END
FLUID DEFINITION: Water
Material = IAPWS WATER
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
FLUID: Vapour
FLUID BUOYANCY MODEL:
Option = Density Difference
END
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
TURBULENCE MODEL:
Option = Dispersed Phase Zero Equation
END
END
FLUID: Water
END
Include Viscous Dissipation Term = On
END
TURBULENCE MODEL:
Option = SST
BUOYANCY TURBULENCE:
Option = Production
Turbulent Schmidt Number = 0.9
END
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
Homogeneous Model = False
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
END
END
Surface Tension Coefficient = SurfaceTensionCoefficient
INTERPHASE HEAT TRANSFER:
Option = Two Resistance
FLUID1 INTERPHASE HEAT TRANSFER:
Option = Zero Resistance
END
FLUID2 INTERPHASE HEAT TRANSFER:
Option = Ranz Marshall
END
END
INTERPHASE TRANSFER MODEL:
Option = Particle Model
END
MASS TRANSFER:
Option = Phase Change
PHASE CHANGE MODEL:
Option = Thermal Phase Change
Saturation Temperature = SaturationTemperature
WALL BOILING MODEL:
Option = RPI Model
END
END
END
END
END
END
END
END
MOMENTUM TRANSFER:
DRAG FORCE:
Option = Ishii Zuber
END
LIFT FORCE:
Option = Tomiyama
END
TURBULENT DISPERSION FORCE:
Option = Favre Averaged Drag Force
Turbulent Dispersion Coefficient = 1.0
END
VIRTUAL MASS FORCE:
Option = Virtual Mass Coefficient
Virtual Mass Coefficient = 0.5
END
WALL LUBRICATION FORCE:
Lubrication Coefficient C1 = -0.05
Lubrication Coefficient C2 = 0.01
Option = Antal
END
END
SURFACE TENSION MODEL:
Option = Continuum Surface Force
Primary Fluid = Water
Volume Fraction Smoothing Type = Volume-Weighted
END
TURBULENCE TRANSFER:
ENHANCED TURBULENCE PRODUCTION MODEL:
Option = Sato Enhanced Eddy Viscosity
END
END
END
INITIALISATION:
Option = Automatic
FLUID: Vapour
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
TEMPERATURE:
END
VOLUME FRACTION:
Volume Fraction = 0
END
END
END
FLUID: Water
INITIAL CONDITIONS:
U = 0 [m s^-1]
V = 0 [m s^-1]
W = 0 [m s^-1]
END
TEMPERATURE:
END
TURBULENCE INITIAL CONDITIONS:
Option = Low Intensity and Eddy Viscosity Ratio
END
VOLUME FRACTION:
Volume Fraction = 1
END
END
END
INITIAL CONDITIONS:
STATIC PRESSURE:
END
END
END
MULTIPHASE MODELS:
FREE SURFACE MODEL:
Option = Standard
END
END
END
OUTPUT CONTROL:
BACKUP RESULTS: Backup Results 1
File Compression Level = Default
Option = Standard
Output Equation Residuals = None
OUTPUT FREQUENCY:
Elapsed Time Interval = 2 [h]
Option = Elapsed Time Interval
END
END
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   June 8, 2011, 13:13
Attesz's Avatar
Attesz
MONITOR OBJECTS:
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR POINT: BoilCheck1
Cartesian Coordinates = 0.0337414 [m], 0.01 [m], 0.004 [m]
Domain Name = FLUID_WATERJACKET
Option = Cartesian Coordinates
Output Variables List = Vapour.Volume Fraction
END
MONITOR POINT: BoilCheck2
Cartesian Coordinates = 0.0917695 [m], 0.01 [m], 0.004 [m]
END
MONITOR POINT: BoilCheck3
Cartesian Coordinates = 0.143128 [m], 0.01 [m], 0.004 [m]
END
MONITOR POINT: BoilCheck4
Cartesian Coordinates = 0.180127 [m], 0.01 [m], 0.004 [m]
END
MONITOR POINT: InletTemp
Cartesian Coordinates = 0.306848 [m], 0.0938528 [m], 0.0615971 [m]
Output Variables List = Water.Temperature
END
MONITOR POINT: OutletTemp
Cartesian Coordinates = 0.203647 [m], 0.0409154 [m], 0.16532 [m]
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
RESULTS:
Option = Standard
Output Equation Residuals = All
END
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = Upwind
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 3000
Minimum Number of Iterations = 500
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Conservation Target = 0.01
Residual Target = 0.000001
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
END
EXPERT PARAMETERS:
tbulk for htc = 354.5
wall clock time = t
END
END
COMMAND FILE:
Version = 13.0
Results Version = 13.0
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 2
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: bu2s0037
Host Architecture String = linux-amd64
Installation Root = /data/progs/ansys_inc_130/v%v/CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Initial Partition File = \
Run Mode = Full
Solver Input File = \
INITIAL VALUES SPECIFICATION:
INITIAL VALUES CONTROL:
Continue History From = Initial Values 1
Use Mesh From = Initial Values
END
INITIAL VALUES: Initial Values 1
File Name = \
Option = Results File
END
END
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 8
Start Method = HP MPI Local Parallel
END
END
END
END
Old   June 8, 2011, 20:55
Does it work when you use constant properties water? IAWPS properties are always harder to converge.
Old   June 9, 2011, 05:45
Attesz's Avatar
Attesz
Thanks, I haven't tested it yet, I will give it a try.
The interesting thing is when the vapour phase appears its temperature increases up to 300000K and then it crashez. If I switch to transient simulation and adaptive time step, the solver goes to very small step size (1e-9 s) while the P-Vol residuals grows continously until crash. So the problem is with the phase change and vapour generation or maybe with the heat transfer modelling between the phases...
Old   June 9, 2011, 06:52
Precisely. So to check whether the problem is in the material properties or you rmodel, run a simple constant properties model and see if it works.
Old   June 9, 2011, 07:27
Attesz's Avatar
Attesz
Ok, I start a new simulation with constant properties.
Otherwise I get:
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 127. No results |
| file has been created. |
What is the 127 code means in this case?
Thank you!
Old   June 9, 2011, 08:11
No, the error codes are not documented unfortunately. But you probably missed something necessary to define the simulation in the material properties.
Old   January 5, 2013, 03:32
Abishek is on a distinguished road
you have to force the vapor phase temperature to saturation temperature to be able to use the RPI wall boiling model. hence, the solver will not run the energy equation for vapor phase..
Abishek is offline   Reply With Quote
boiling
Two-phase Eulerian model for nucleate subcooled boiling Edy OpenFOAM 5 February 11, 2017 16:21
Free water jet impinging hot solid surface, including boiling hamdy Fluent UDF and Scheme Programming 5 August 19, 2012 19:52
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 12:00
Boiling of water with hot air Dr. Flow Squad CFX 2 July 27, 2009 07:37
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
