March 12, 2013, 07:24 |
free convection inside tube
Hello!! i am new in CFX and a need your advise in a simulation i am trying to perform. My geometry consists of a vertical conical tube. All i want to do is to set different values for temperature at the top and the bottom boundary in the same time and as a result create recirculation inside tha tube. My working fluid is water. The geometry dimensions are:
Any advice on the boundary conditions I should use? |
March 12, 2013, 07:51 |
Mr CFD
Hi! I suggest you visit my thread: http://www.cfd-online.com/Forums/cfx...er-guides.html as I have a similar problem setup.
Your units of length are microns! Are you sure about this? As you have 3 microns diameter at the bottom and 1 micron diameter at the top your aspect ratio is not homogeneous. I'm not sure if Rayleigh Bernard theory will cover non homogeneous aspect ratios. I suggest you read Fundamentals of Heat and Mass Transfer by Incropera and DeWitt, namely Chapter 9. Also, read Physical Fluid Dynamics by Tritton chapters 4, 14, 16, 17 and 22. The book is quite short and those chapters can be read in a few hours of good reading. |
March 12, 2013, 18:17 |
Rep Power: 143 |
As stated in the previous thread already quoted, the key non dimensional number is the Rayliegh number. I suspect the Ra number here is quite low meaning the flow is laminar and dominated by conduction.
The bounadry conditions you describe sound trivial to set up. Have you done the tutorials? |
March 13, 2013, 04:09 |
I have solved the most of the tutorials. I am quite familiar on the free convection theory but i am still learning. Please give me at first some advice on the kind of boundary conditions you would use in an enclosure similar to this supposedly that the aspect ratio is low and the Rayleigh convection is valid. i think wall at different constant temperatures for the top and bottom plates and adiabatic wall for the rest boundary. the run could be both steady state and transient?
March 13, 2013, 07:02 |
Rep Power: 143 |
The boundary conditions must match what you are modelling. I have no idea what you are modelling so cannot help. If you describe what you are modelling we might be able to help you.
March 13, 2013, 07:10 |
Mr CFD
Please provide an annotated diagram. The annotations should state what your boundary conditions are.
conical tube, free convection |
How do I set a boundary at a hole inside the tube | Theerawat | FLUENT | 4 | July 16, 2012 08:07 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 05:12 |
[ICEM] meshing tube inside pipe | Tres | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:11 |
Argon gas inside a steel tube? | rskrishna87 | CFX | 3 | April 27, 2011 20:26 |
Tube inside a tube simulation | Rashmichem | Main CFD Forum | 0 | December 14, 2010 02:52 |
