April 10, 2018, 04:02 |
Particle tracking Transient CFX
Suman Sapkota
Rep Power: 8 |
Hello all,
I am doing transient simulation of free impeller of centrifugal pump. The conditions defined are: The pump completes 1 rotation in 0.2307 s. So, this is the total time taken. Time step is total time/50 to save computation time. convergence loop 1 to 3. Inlet b.c: uniform velocity=6 m/s At time t=0, u=v=w=0 m/s outlet: average static pressure=10^6 Pa Particle bc at inlet: normal speed: 6 m/s, uniform injection, number rate 1000, mass flow rate: 0.01 kg/s Particle Control is in defaults. The streamline reaches till the output but the particle tracking when I see the result file, it does not reach the blade. What should I do to track the particle all the way? Is it due to the defaults particle control? |
Streamlines or massless particle tracking in CFX | driu | CFX | 12 | June 2, 2017 08:28 |
CFX vs FLUENT for particle tracking simulation | iman | ANSYS | 2 | August 31, 2012 20:34 |
Lagrangian Tracking in CFX (Multiphase flow) | inotin | CFX | 3 | June 17, 2012 19:58 |
Particle Tracking for ion | Jun | CFX | 2 | August 31, 2010 08:19 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
