June 4, 2013, 16:31 |
Dynamic mesh test
Bernardo Blasi Villari
Hello everyone,
Is it possible to verify if a mesh is working correctly on CFX through some sort of animation, report, or something like that? I would like to see if the displacement condition that i put on it is correct. I'm meshing a compression chamber of a compressor and the piston displacement seems to be wrong. Thank you very much in advance |
June 5, 2013, 06:05 |
Rep Power: 143 |
Send the expression you are using to control the piston motion to a monitor point set to that expression. Then you can monitor it in the solver manager as the simulation progresses.
June 5, 2013, 14:22 |
Thank you very much, ghorrocks. I'll try that
compression piston engine, dynamic meshing |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
