June 25, 2013, 07:51 |
radiation in glass plate
Hello guys.
I have a problem with radiation simulation. I simulate flow in the winter garden including sun heat flux. I want to compare different types of glasses (three-plate vs. two-plate etc.). If I use Discrete Transfer radiation model, everything is OK if I set radiation up only on fluid domain. But I want to simulate radiation through the windows so I suppose that I need to define radiation model also for solid domain so I have to use Monte Carlo for both domains. But as soon as I run the calculation with MC model, I get strange results (temperatures between -50 and 300°C). The radiation source is on grey wall with mesh displayed (600 W/m^-2). I defined material properties (scattering and absorbtion ceoffs and refractive index) for glass and I left all the interfaces as a default. And this is what I don't know how to set up. Can anyone help me with that? Any idea could help... Thanks in advance. Best Regards |
June 25, 2013, 18:58 |
Rep Power: 143 |
I presume then you want to model transmission, reflection and absorption in the glass. I do not think the discrete transfer model can handle this, I think you will need the full Monte Carlo model to do this.
If the Monte Carlo model is giving strange results then I suspect it is not fully converged yet, or you do not have enough rays to accurately model the heat transfer. Can you post your CCL? |
June 27, 2013, 01:10 |
Thank you for reply.
Yes you are right that is what I want to define and check. And because MC is the only radiation model available for solids I have to use it. I attached CCL and two pictures to see what I obtained. The contours are identical, the only difference is in variable range (post1.png - user specified range, post2.png - local range). Just to see nonrealistic values. In CCL please note that "okna" domain represents windows. Thank you in advance for reply. Best Regards |
June 27, 2013, 01:16 |
Rep Power: 143 |
That is exactly what happens when the radiation model is too coarse. Try reducing the radiation ray tracing coarsening factor.
June 27, 2013, 01:57 |
Excuse me, what do you mean exactly? Where I can find it please? Cause I don't know what you mean exactly right now
June 27, 2013, 02:06 |
Rep Power: 143 |
THERMAL RADIATION CONTROL: Diagnostic Output Level = 1 Iteration Interval = 3 COARSENING CONTROL: Target Coarsening Rate = 32 END END |
June 27, 2013, 02:07 |
OK I'll try. Thank you very much Glenn.
June 27, 2013, 08:13 |
So I tried to decrease coarsening rate to 8 and calculated radiation each 2 steps but it is still the same. What is wierd to me is that when I check radiation coarsening information just in partitioning it shows me that I get only 1 radiation element from 2.4M elements. Is it possible to force it somehow or just to have "power" to affect this coarsening? I know that there are few other options but I don't know which one could be appropriate.
June 27, 2013, 18:41 |
Rep Power: 143 |
There are a lot of radiation options and to be honest I do not know them all well. But I can say the image you showed was typical of poor radiation resolution and/or accuracy, so it looks like adjusting the radiation defaults is required in your case. So I would adjust all relevant looking radiation controls and look at their impact.
problem in glass radiation model (DO model) | wunan805 | FLUENT | 0 | October 10, 2012 05:06 |
Aluminium Plate Heated by Solar Radiation | Allankey | FLUENT | 0 | May 29, 2012 13:45 |
Radiation through: glass – air cavity – glass | Yingchun | CFX | 7 | February 27, 2012 16:46 |
radiation through glass | amrjoao | FLUENT | 0 | July 19, 2011 10:18 |
ACOUSTIC RADIATION behavior of a plate with mass distribution | rickyben | ANSYS | 0 | August 22, 2009 07:38 |
