July 10, 2013, 05:38 |
CFX POST Geometry Scaling
Rep Power: 14 |
HI!
Is there a way to scale a geometry in CFX Post? I have simulated a pipe with 0.015 m Diameter and a Length of more than 1 m. For a better visualisation I wish to "shrink" the length to 25% or smth. just for Visualisation pruposes without affecting e.g. the Diameter. Is there a known Way to do this? Thx! |
July 10, 2013, 09:56 |
Edmund Singer P.E.
Rep Power: 20 |
For all objects, go into the object window details, there should be a VIEW tab. Under the view tab there is a scale. Check that and adjust as you see fit.
The scale applies to X,Y,Z coords, so for simplicity, hopefully your geometery lines up. |
July 11, 2013, 04:01 |
Rep Power: 14 |
Thx a lot!
Exactly what I was looking for! Though as an explanation for any one else (because I needed some try to figure it out myself ): If you want to draw a plane to show e.g. the pressure repartition it is sufficient to edit the "View" Tab of the "Plane" and define there a scaling factor <- this what singer1812 meant when mentioning the object window details No need to try to scale all geometry parts Allthough one notice: The geometry will not follow / line up. Thx again singer! |
cfx post, geometry, scaling |
Two way FSI post processing in CFX | ashli217 | ANSYS | 0 | May 3, 2013 05:43 |
Heat Release in CFX Post | kapopadu | CFX | 0 | April 12, 2013 07:33 |
CFX Post add user surface | Zigainer | CFX | 0 | October 2, 2012 08:57 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Assign new variable in CFX Post | Ben | CFX | 1 | August 25, 2008 14:59 |
