August 26, 2013, 06:31 |
Wind turbine simulation
Ali Khalifesoltani
Hi dear experts,
I am going to simulate a mini horizontal axis wind turbine with Ansys CFX. The analysis will be both aerodynamic and structural.(two way FSI) my problem is that I do not know about the aerodynamic configuration of this problem. I doubt about the settings of the two domains(stationary and rotating). how should be the BCs? another problem is definition of angular velocity of rotating domain , as the wind turbine rotates due to the linear wind speed that passes through the rotor blades. how should I define the angular velocity? any further guideline is appreciated. thanks in advance. Ali Last edited by asoltoon; August 27, 2013 at 04:09. |
August 28, 2013, 00:33 |
Ali Khalifesoltani
any opinion is helpful, please write your suggestions....
regards |
August 28, 2013, 01:56 |
Rep Power: 143 |
What are you doing the FSI for? Is the structure deforming or is this to get the device operation speed?
August 28, 2013, 04:13 |
Ali Khalifesoltani
hi ghorrocks,
I wanna simulate both aerodynamic effects and deformations in the structure due to the wind speed. both the rotor rotational speed and deformation of the structure is important for me. best regards |
August 28, 2013, 06:35 |
Rep Power: 143 |
There is a lot of new stuff for blade flutter in turbomachinery in CFX V15. A beta version is currently available. Talk to CFX support about access to it.
August 28, 2013, 07:13 |
Ali Khalifesoltani
Thank you Glenn for the reply,
But what about the setup configuration for rotating blade, the boundary conditions, domains, etc.? |
August 28, 2013, 07:18 |
Rep Power: 143 |
Ignoring the FSI - Rotating blades are just straight forward rotating machinery, the boundary conditions don't sound any different to the usual and the domains are elementary. There are tutorials and best practises guides which show how all this is done.
But adding deformation will make it much more complex. The new blade flutter stuff looks relevant, so I strongly recommend you look at getting the new beta CFX V15. |
Torque of wind turbine simulation | caohan | FLUENT | 8 | August 11, 2014 23:01 |
Moving reference frame in wind turbine | kongl1986 | FLUENT | 0 | March 30, 2013 10:50 |
simulation on wind turbine... | qiba123 | Fidelity CFD | 1 | May 27, 2012 21:47 |
wind turbine simulation, Ansys Post results question | Laions | CFX | 7 | September 20, 2011 05:13 |
3D simulation of wind turbine in Yaw wind(in a lateral wind) | mohammad | Main CFD Forum | 0 | December 28, 2010 03:26 |
