September 18, 2013, 03:59 |
Memory Error
Rep Power: 12 |
Hy,
can anybody help me with this kind of error? I am beginner and try a fluid flow throught a hollow zylinder as a heat source. That would be really nice! Thx Michaela Couldn't initialise lpnquery library +--------------------------------------------------------------------+ | | | Solver | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Solver 14.5.7 | | | | Version 2013.03.12-10.53 Tue Mar 12 11:06:45 GMTST 2013 | | | | Executable Attributes | | | | single-int32-64bit-novc8-noifort-novc6-optimised-supfort-noprof-nos| | | | (C) 2013 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: serial run Host computer: xxx (PID:5424) Job started: Wed Sep 18 09:54:13 2013 Details of error:- ---------------- Error detected by routine PEEKI CDANAM = /LPNQ/DB/NREG CRESLT = NONE Current Directory : /FLOW/REGMAP +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine MEMERR | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. This run of the ANSYS CFX Solver has finished. |
September 19, 2013, 03:59 |
lpnquery library
Rep Power: 12 |
Hy CFX-Community,
does anybody know what a lpnquery library means? Thx and Greets Michi |
September 19, 2013, 05:53 |
Rep Power: 143 |
I have no idea. It is some weird thing you have set up. But as you have given no details about what you are doing or how you are doing it there is not much we can do to help.
http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F |
September 20, 2013, 04:11 |
Rep Power: 12 |
Dear Horroks,
ok, true ! I am trying to simulate an air flow ( for temperature and velocity distribution) through a choke coil (dimensions: diameter: 2m, height: 2,5 m) The choke coil looks like a hollow cylinder with a wall thickness of 10 cm with a 3layers ( ring).Between every layer is a gap of 5 cm . Air flows througth it and cools the choke (like a convector) The boundary conditions of the surrounding (on a free ambient field)are inlet at the right side, outlet at the top, left side opening, back side and ground as wall. The choke material is aluminum with a source cooled by air flow. I have already got some results for similar conditions and body. I changed the geometry ( from 5 layers to 3 layers) and the mesh of an existing similar working simulation of a choke coil. But this time when I start the solver, it stops after a few seconds and I get this error. It even doesn't start mounting the mesh. Since the older version is working I thought about old parameters which cause the problem. Nevertheless I try to start the whole thing from zero and not from an existing file. This should help! Thanks!!! Michi |
September 20, 2013, 06:15 |
Rep Power: 143 |
Can you post an image of what you are modelling and your CCL?
September 25, 2013, 10:28 |
Rep Power: 12 |
Dear Horrocks,
thanks for your help!! I found error. There was a bad connection with the domains and interface connections in the setup. I turned the automatic default Domains and Interfaces off during setup generation and they where not shown. I went to Edit-->Options-->General and turned Default Domains on. Then I got some hints! |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
