October 1, 2013, 06:00 |
multiple inlet as one inlet
amin gls
Rep Power: 13 |
hello to all , i have a question about multiple inlet as one inlet , i have for example 80 pipes as inlet that all of them should have 0.5 cm/s as inlet velocity , i selected them as inlet in cfx meshing , when i set inlet velocity to 0.5cm/s . i dont get this velocity in cfd result , anybody can tel me what shall we do to get 0.5cm/s in each inlet . thanks ,
October 1, 2013, 20:47 |
Rep Power: 143 |
Please post an image of what you are seeing.
October 2, 2013, 08:59 |
Gert Lindner
Rep Power: 17 |
Suppose you have a main direction for downstream flow of a pipe system. Then additional (multiple) inlets discharge in a junction section under an angle of inclination into. This angle affects the flow regime depending of mass flow rate coming from side inlets. A T- junction geometry may results in a nearly counter flow while a conform flow is induced by a Y-geometry for example.
Regards Gert |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Inlet shapes for modelling a fan in an inlet duct | buzzybee | CFX | 10 | June 11, 2009 20:15 |
Multiple Inlet Problems | Neetin Lad | Main CFD Forum | 0 | September 20, 2007 13:40 |
transitional inlet boundary condition | kamp | CFX | 1 | June 21, 2006 11:08 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
