October 17, 2013, 05:53 |
Handling Humidity in CFX
sunil
Rep Power: 13 |
Hello everyone,
I successfully simulated effect of outdoor conditions on room temperature by considering air as Dry (Air at 25 C). now i want to simulate the same by considering humidity (i.e RH = 30%, 40%, 50%, 60%) how to add humidity effect in CFX Thank you |
January 1, 2017, 05:02 |
did you find the answer??
behrouz
Rep Power: 11 |
hi Sunil
did you find how model the humidity in cfx??? |
January 1, 2017, 05:58 |
Rep Power: 143 |
The obvious thing to do is to use a multi-component mixture (NOT multiphase) to model the water mass fraction.
January 1, 2017, 06:35 |
behrouz
Rep Power: 11 |
thank you Glenn,
as alwase responsible and helpfull. |
January 4, 2017, 04:19 |
sunil
Rep Power: 13 |
Hi behrouz,
I am unable to model humidity effects, still I m trying Thanks Sent from my MI 4W using CFD Online Forum mobile app
Regards, Sunil |
January 4, 2017, 17:15 |
Rep Power: 143 |
Have you looked at the CFX tutorial examples? They are available on the ANSYS customer webpage. There are a few examples which use multi-component mixtures so I recommend you have a look at them.
If you just want a simple humidity model then define a multicomponent mixture, with the components being dry air and water vapour. If you use simple equations of state like constant properties or ideal gas then it should be pretty numerically robust. Then define your mass fractions at initial condition and boundaries. If you want parameters like relative humidity or wet bulb temperature then you will need to define a expression to evaluate this from the mass fractions. |
January 14, 2020, 09:07 |
Rep Power: 11 |
Mr Ghorrocks. Yes you are correct, Multi component needs to be used but how to get Wet Bulb Temp and Relative humidity as Output
Thanks |
January 19, 2020, 03:25 |
Rep Power: 143 |
Define CEL expressions to calculate it from the mass fractions.
%rh, relative humidity |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
