March 25, 2014, 02:44 |
cel allow boundary normal = t
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I received the following error at the beginning of my simulation; Boundary normal vectors cannot be used for CEL in this way, | | as they are not normally available at boundary mesh vertices. | | However, this can be over-ridden by setting the Expert Parameter: | | "cel allow boundary normal = t" | | This is a beta-feature, and will average the adjacent face normals | | to the vertex. Check subsequent results carefully. In Expert Parameters there is no option for cel allow boundary normal. Does anybody know where this option is? Regards, AshtonJ |
March 25, 2014, 03:11 |
Lance
Rep Power: 22 |
You might need to add it manually through the command editor (right click on expert parameters and copy/paste into the editor). However, as the warning says, check your results carefully.
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
