April 20, 2014, 23:42 |
How to generate force historical file?
Antoni Alexander
Rep Power: 16 |
Hello everyone,
I am using terminal command line on Linux cluster to run cfx. Since there is no graphics, so I can not see the point monitor such as lift drag defined in cfxpre. Then I tried to find a way to output the force historical file, but it turned no good. So, has anybody ever faced the same problem? Could cfx generate the monitor point in a file? And how? Any suggestions will be appreciated! Best regards. |
April 21, 2014, 03:41 |
Rep Power: 143 |
You can setup linux to display graphics with x or mesa or lots of other options. There should be no reason you are limited to a command line.
You can load the results file on any machine (even a different OS) and load it into CFX-Monitor and export the data points you want. Alternately you can use cfx5mon on the command line to export it directly. Look up cfx5mon in the documentation for how to use this function. |
April 22, 2014, 07:18 |
#3 | |
Antoni Alexander
Rep Power: 16 |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
patch error OF v2.2.2 mac | hewei | OpenFOAM Installation | 4 | November 30, 2013 16:55 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
