April 21, 2014, 03:41 |
Rep Power: 143 |
You can setup linux to display graphics with x or mesa or lots of other options. There should be no reason you are limited to a command line.
You can load the results file on any machine (even a different OS) and load it into CFX-Monitor and export the data points you want. Alternately you can use cfx5mon on the command line to export it directly. Look up cfx5mon in the documentation for how to use this function. |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
patch error OF v2.2.2 mac | hewei | OpenFOAM Installation | 4 | November 30, 2013 16:55 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
