Problems about streamline in the axial diffuser |
May 27, 2014, 12:51 |
shaodong
Rep Power: 12 |
Hi, all.
This is my simulation of one centrifugal compressor. The BC of inlet is 1 atm for total pressure, 288.15 K for total temperature, axial direction for flow direction, and the BC of outlet is 3.4 atm for static pressure. The rotating speed of impeller is 28000 rpm. When I checked the results in the view of B2B in CFD-post, I found the streamline in the axial diffuser was curly (the right one)while the upstream streamline in the radial diffuser (the left one )looked normal. Has anyone got this problem before? Thank you for reading my post. |
May 27, 2014, 19:05 |
Rep Power: 143 |
Do you mean the ripples in the streamlines?
This could be a numerical artifact: * Rerun with a finer mesh * Converge tighter * Better mesh quality and see if it goes away. OR it could be real. Turbulence transition looks somewhat like that. |
centrifugal compressor, cfx, diffuser |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
[ANSYS Meshing] How to refine a diffuser mesh in axial and circumferential directions seperately ? | ulvi90 | ANSYS Meshing & Geometry | 0 | December 10, 2013 08:19 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
how to plot out circumferentially mass averaged axial velocity in a rotor? | wildli | FLUENT | 0 | July 17, 2010 15:54 |
About the design of axial fans | HanCheolHeui | Main CFD Forum | 0 | September 8, 1998 10:13 |
