July 3, 2014, 19:50 |
Inferring a stream line plot
Rep Power: 17 |
I know that when stream lines are close it implies a region of high velocity and when the stream lines are far apart it implies a region of low velocity.
But when a stream line plot is made in CFD Post, the distribution of stream lines is just dependent on the number of points chosen in the settings. So could someone please explain how to locate regions say sparsely populated with streamlines, I mean by doing away with this sensitivity to the number of points in the settings.
Best regards, Santhosh. |
July 3, 2014, 21:37 |
Rep Power: 143 |
Why not just look at the velocity magnitude and see the areas of low velocity directly rather than inferring them from the streamlines?
July 4, 2014, 08:51 |
Rep Power: 32 |
You said
HTML Code:
I know that when stream lines are close it implies a region of high velocity and when the stream lines are far apart it implies a region of low velocity. "when equally distributed stream lines (delta Psi = constant) are close it implies a region of high velocity and when the stream lines are far apart it implies a region of low velocity" |
July 9, 2014, 03:05 |
Marcin
Rep Power: 12 |
you can define plane on the are which you intersted. ANd from this plane you can define streamlines
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
