Does local boundary condition overwrite the global/domain ones?
Old   September 2, 2014, 04:58
Default Does local boundary condition overwrite the global/domain ones?
Pavel
powpawell is on a distinguished road
I am wondering if the local boundary conditions (e.g. inlet, top, outlet) overwrite the whole domain initial conditions. If the domain's pressure is 1atm and I set hydrostatic pressure for outlet, will the former be added to the latter?
Or if I add 2 inlet conditions (e.g. velocity due to waves and tidal current velocity)...what happens in this case?
Any help is highly appreciated!
Thanks very much!
powpawell is offline   Reply With Quote
Old   September 2, 2014, 08:29
Opaque will become famous soon enough
It will be good to read the documentation
CFX-Solver Theory Guide: Chapter 11: Discretization and Solution Theory | 11.1. Numerical Discretization
The initial conditions are to initialize the control volume values, while the boundary condition are applied at the integration points of the element faces at the boundary of interest. There is not overlap between the values; therefore, nothing to worry about.
Of course, you do not want to initialize the control volume pressure value to say 1MPa while the boundary condition of the integration point next to it is set to 0.01MPa (or 100MPa). It will drive the flow crazy until the solution converges (if it does).
Hope the above helps.
Opaque is offline   Reply With Quote
Old   September 5, 2014, 04:40
Pavel
hi Opaque,
Thanks for your answer. This helps
Mathematical representation of fixedDisplacementZeroShear boundary condition Sargam05 OpenFOAM 14 January 11, 2022 06:55
Opening Boundary Condition andreachan Main CFD Forum 11 March 19, 2013 16:46
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 03:11
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
