STRANGE BUT REAL !!!!about the velocity at wall BCs |
September 4, 2014, 22:54 |
mohammad
Rep Power: 16 |
Hello everyone,
I was trying to explore some simple thing. I created a simple duct, and then simple inlet outlet and walls. amazingly, when I extracted the nodal velocity values on all wall BCs using FILE>Export>.... , they are not zero.!!!! ( walls are no-slip, though) I extracted the velocity contours on the wall, they are zero. I shared this problem with my supervisor. and he told me that they values are being calculated on each cell centet point and then interpolated on the vertices... Is that correct??? Last edited by mohammad; September 5, 2014 at 05:30. |
September 5, 2014, 04:59 |
Rep Power: 11 |
Yes, the at the walls are represented by volumes and actual boundaries of these volumes away from walls. So you see velocity on the wall. If you want it zero, choose hybrid velocity instead of conservative in CFD Post. http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
September 5, 2014, 06:41 |
Rep Power: 143 |
I think the FAQ you were trying to reference was this one: http://www.cfd-online.com/Wiki/Ansys...t_the_walls.3F
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Influece of wall velocity in the main flow | marvin | CFX | 0 | March 22, 2008 02:05 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Wall BC's for a NS solver | André Burdet | Main CFD Forum | 6 | December 8, 2000 21:45 |
