How does CFX treat an opening when heat transfer is modelled? |
September 8, 2014, 07:23 |
Mr CFD
For the transfer of heat to occur, there has to be a driving force. I.e. a temperature difference.
It is my understanding that the opening temperature is only used when the fluid re-enters the domain. In that case how does CFX determine the driving force at the opening? What is delta T at the opening? What temperature difference does CFX use to determine how much heat leaves at the opening? And since it's an opening, a heat transfer coefficient cannot be used. What is the formulation? Is the opening equivalent to implementing a wacking great heat transfer coefficient in the code at the opening with some mass sinks? |
September 8, 2014, 18:12 |
Rep Power: 143 |
No. At an opening the temperature at the boundary is dependant on the flow direction:
If the flow is out of the domain then the boundary temperature is convected from the interior nodes. If the flow is into the domain then the boundary temperature is set as the defined temperature. |
September 9, 2014, 05:34 |
Mr CFD
Thank you.
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 18:46 |
CFX wall heat transfer coefficient | mactech001 | CFX | 1 | January 5, 2010 21:33 |
STAR, Fluent, CFX and conj. heat transfer | star-user | Main CFD Forum | 8 | January 21, 2003 00:07 |
