September 26, 2014, 12:10 |
Solid Definitions on Fluid porous interface
Sangwook Kim
Dear all,
I am conducting battery simulation. To research interface between electrode and electrolyte, I modeled 2 cubic. I set electrode as porous domain. As you can see, there are no more option at solid definitions, only aluminum, copper, and steel. Although I tried import material library, it is not working. How can I change solid material?? is it impossible to change when i use porous domain?? Thank you Sangwook Last edited by kimsw0103; September 26, 2014 at 13:47. |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Radiation at interface between fluid and porous domain | Hitch8 | CFX | 19 | April 20, 2015 06:24 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Fluid Solid Interface in Fluent | saisanthoshm88 | FLUENT | 2 | July 17, 2012 05:31 |
