Peekr error
Old   October 2, 2014, 18:25
Default Peekr error
Carlos Diaz
carroddiaz is on a distinguished road
HI EVERYONE,
I HAD BEING TRYING TO START THE SIMULATION FOR A FLAMELET COMBUSTION MODEL IN A CFX 15.0, BUT AT THE VERY BEGINING OF THE SOLVER PROCESS, IT COMES A MESSAGE AS THIS
Error detected by routine PEEKR
CDANAM = TDLIMIT/VALUE
CRESLT = NONE
Current Directory : /FLOW/ALGORITHM/ZN1/CONTROL/FL1/TDAMP
I READ IN THE HELP ARCHIVES AND IT SAYS THAT PEEKR ROUTINE IS FOR THE MEMORY MANAGEMENT, I TRIED PUTTING THE .DEF FILE IN THE "HOME" DIRECTORY BUT IT STILL APPEARS.
I WOULD LIKE IF SOMEONE KNOWS HOW CAN I FIX IT
WITH BEST REGARDS,
CARLOS DIAZ
carroddiaz is offline   Reply With Quote
Old   October 22, 2014, 20:40
Carlos Diaz
Just for the record, this is how I fix it.
The blame of this is due to the TDAMP value, that push the solver to overflow in the solution.
so I set this to 0.1 and solved...
See you for the next
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
