Rigid body simulation
Old   October 13, 2014, 03:28
Default Rigid body simulation
shikha
SHIKHA BHUYAN is on a distinguished road
Hello Friends,
I am trying to study the movement of a plate that will be generated on external water inlet.
For that I have created 3 domain:
(a) Stationary domain;
(b) Rotating domain;
(c) plate (target body;boolean with the rotating domain)
And then formed "A NEW PART" so as to form interface.
I have set the CFX-pre settings. However, error pop-up when I start the solver.I am attaching the outfile for your convenience.
Please help me for this problem. Any helping hand will be highly appreciated.
SHIKHA BHUYAN is offline   Reply With Quote
Old   October 13, 2014, 05:21
The error message is very clear. All your nodes are on boundaries for a domain. You need to have some nodes in the centre of the domain. You are going to have to mesh with some internal nodes.
Old   October 13, 2014, 05:57
shikha
Thank you sir for your reply.
If I am getting it correctly (as I am not a expertise in this field), I have to mesh the domains with bodymeshing that will create internal nodes.
Old   October 13, 2014, 06:09
Any meshing technique will fix the problem. Anything which will result in internal nodes.
Old   October 15, 2014, 00:13
shikha
Thank you sir for your reply!I could do the simulation on the plate and have run the solution in cfx (out file could not be attached due to high memory). In the result file the animation has to be shown. But the plate does not move on the influence of water inlet.
The out file seems to be ok for me as no error is showing there. If you can throw any light in this situation.
Ahmed Body Simulation nick FLUENT 5 December 24, 2018 11:13
6-dof rigid body solver AUN CFX 4 October 3, 2017 19:49
monitor point on rigid body ghoroobeaakhar CFX 0 April 15, 2014 15:09
CEL code for simulating the equation of motion of a vibrating rigid body mohamadaliv CFX 11 October 19, 2011 04:30
LES simulation of bluff body at Re(d)=1200 arash_nl FLUENT 0 June 1, 2009 13:16
