November 12, 2014, 00:30 |
Centreline of a 3D Geometry
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I need to find the centreline of 3D arterial models in CFD Post. Does any body have an idea of finding the centreline of a 3D model? Thanks AshtonJ |
November 12, 2014, 05:52 |
Rep Power: 143 |
Define a series of cross sections along the length of the object. Find the centroid of each cross section (sum(y*area)@CrossSection/area()@CrossSection or something like it to find the y location of the centroid for a cross section). Then put a polyline through the centroid points.
November 12, 2014, 06:05 |
Ashkan Javadzadegan
Rep Power: 16 |
Thanks Glenn.
I need to find the normalised vector of centreline and dot product it by velocity to determine the extent of flow recirculation. Is this doable? |
November 12, 2014, 16:58 |
Rep Power: 143 |
That will be tricky analysis to do in CFD-Post. I would generate the centreline as I describe in CFD-Post, but probably do the dot product to get your recirculation number in an external package. I would use python, but matlab is another good choice.
November 12, 2014, 17:05 |
Ashkan Javadzadegan
Rep Power: 16 |
Thanks Glenn.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
[GAMBIT] import terrain geometry | cfdworker | ANSYS Meshing & Geometry | 2 | May 24, 2009 21:40 |
