March 9, 2015, 06:32 |
Turbulent prandtl number
kiarash kiani
Rep Power: 11 |
Dear experts,
I want to modify turbulent prandtl number (Prt) as a function of "Yplus". I defined an expression in CFX-pre and then the new expression was added to turbulence setting... and there was no error message. However, during solution CFX gives the error below: "Error in subroutine get_YPLUS_TURB Error calculating Yplus GETVAR originally called by Subroutine DEF_DIFTRBC" I will be greatful if someone expert help me handle this problem. Thanks. |
March 9, 2015, 06:44 |
Lance
Rep Power: 22 |
It is hard to help by guessing...
What was the CEL expression? Show your ccl? |
March 9, 2015, 07:30 |
kiarash kiani
Rep Power: 11 |
I did this:
"************************************************* *** Insert/Epressions,.../Expression then, I defined a new expression named "Prt2" .../Definition if(Yplus<=11.6, 8.8e-4*Yplus^3-0.0239*Yplus^2+0.238*Yplus+0.0836, 0.75) then Domain/fluid model/Turbulence/Turb. flux closure for heat... Turb. Prandtl Num. : Prt2 !************************************************* *** Thanks. |
March 9, 2015, 07:48 |
Lance
Rep Power: 22 |
I dont get it.
The Y+ variable is a surface quantity while the turbulent Prandtl number is present in the entire domain, so I cant see why your expression should work. What is it based on? What do you want it to do? What about the freestream values? |
March 9, 2015, 08:56 |
kiarash kiani
Rep Power: 11 |
as you know, Prt is just a relation between "vt" and "Kt". some turbulence models like standard k-e keeps the Prt fixed(0.85 or 0.75), however it isn't correct in near wall region and in cases in which nearwall heat transfer is important may lead to large discrepancy. the relation I use is based on DNS simulation of Lu and Hetsroni "Direct numerical simulation of turbulent open-channel flow with passive heat transfer"... the relation just corrects the Prt for near wall cells based on their non dimensional distant to the nearest wall. anyway I think the error isn't physical!! may be its about the solver?!
March 9, 2015, 09:01 |
kiarash kiani
Rep Power: 11 |
Dear Lance
this relation is used in TLVA, " a DNS Based turbulence model". Also see " Near-wall Modelling of turbulent convective heat transfer in film cooling of turbine blades with the aid of Direct Numerical Simulation Data",Djamel Lakehal |
February 13, 2017, 16:59 |
Landy
Hello, (Reza_K) I have the same problem, but with another expression. Could you solve your problem?
I have dealt with several expressions depending on Yplus and Temperature, on both occasions it gives me errors, similar to yours. |
December 1, 2022, 22:29 |
陈晨
Rep Power: 7 |
Dear Reza_K, I have the same problem, could you please help me to solve this problem? I just want to modify the Prandtl number which is a function of Y plus. Thanks a lot.
December 2, 2022, 09:03 |
#9 | |
Rep Power: 32 |
The fact a parameter exists, being a constant or a function, does not mean it is free for all to change. Walk that line carefully.
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
Turbulent Prandtl number | Ravenn | FLUENT | 14 | June 20, 2017 11:13 |
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries | vkrastev | OpenFOAM Pre-Processing | 7 | June 2, 2016 15:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Turbulent Prandtl number | marsnova | FLUENT | 1 | May 3, 2013 10:01 |
